ArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-09-27T09:40:33+01:00 https://brainmodular.org/forums/app.php/feed/topic/6287 2018-09-27T09:40:33+01:00 2018-09-27T09:40:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=6287&p=40193#p40193 <![CDATA[2 little requests about recall grid]]>
Can you please add this to the suggestion forum ? ;)
sorry i'd made a mistake !
Statistics: Posted by joffo78 — 27 Sep 2018, 10:40
2018-09-27T08:11:19+01:00 2018-09-27T08:11:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=6287&p=40192#p40192 <![CDATA[2 little requests about recall grid]]> I had the same problem in the past. So, Senso puted a fade out outlet on the rack settings module. You can set your bus pre or post with a volume module drive by this outlet, the same way you use for pre/post buses with rack output.
But in your case, you need this outlet on the patch settings module, not implemented yet (todo list😣).
You can manage what you want with a fader and a volume and two presets, with a fade between those presets. Tricky. Will be better with the fade out outlet on the patch settings module.
Unfortunately, fade on matrix (and certainely array) are not yet available. On the huge todo list 🤔, the one I have for Senso 🤗
All the best.
Statistics: Posted by SylvainT — 27 Sep 2018, 09:11
2018-09-27T07:38:48+01:00 2018-09-27T07:38:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=6287&p=40190#p40190 <![CDATA[2 little requests about recall grid]]>
Statistics: Posted by nay-seven — 27 Sep 2018, 08:38
2018-09-26T23:29:31+01:00 2018-09-26T23:29:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=6287&p=40189#p40189 <![CDATA[2 little requests about recall grid]]> I think i'll be better if time fade on the grid will be applied to bus output.
in a rack i send several sampler in different patches to a mixer patch with bus.
If i put a sampler patch on the grid, i can't fade it.
I have to put the mixer patch with the trues output. But with this method i can't make a fade on only one sampler.
the second thing is array and matrix data's aren't affected by the time fade on the presets.
it would be cool to for my matrix mixer !
Statistics: Posted by joffo78 — 27 Sep 2018, 00:29
All the best.
