ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2018-08-18T20:24:41+01:00https://brainmodular.org/forums/app.php/feed/topic/62582018-08-18T20:24:41+01:002018-08-18T20:24:41+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40081#p40081Statistics: Posted by 23fx23 — 18 Aug 2018, 21:24
2018-08-18T18:37:30+01:002018-08-18T18:37:30+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40080#p40080 Not sure it's possible to do that with the actual module
Statistics: Posted by joffo78 — 18 Aug 2018, 19:37
]]>2018-08-18T16:36:59+01:002018-08-18T16:36:59+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40077#p40077It was possible on usine 5.80 (and before) but not on this new module. Unfortunatly
Statistics: Posted by joffo78 — 18 Aug 2018, 17:36
]]>2018-08-18T16:14:01+01:002018-08-18T16:14:01+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40076#p40076test here with Launchpad mini too if i press a pad on the LP, it's ok, the matrix react correctly, but the Launchpad itself don't light at all ( if i check the midi out of the patch, it send only 1 note ON, always the same ( normal , it's connected to last clic cell as code 1)
i f i fill all the matrix with the mouse, the LP react, but, here the color error i have:
hope this help
Statistics: Posted by nay-seven — 18 Aug 2018, 17:14
Statistics: Posted by oli_lab — 18 Aug 2018, 02:27
]]>2018-08-17T23:21:06+01:002018-08-17T23:21:06+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40074#p40074Thank you for interseting on this subject. here is the manual regard. JF
Statistics: Posted by joffo78 — 18 Aug 2018, 00:21
]]>2018-08-17T11:52:37+01:002018-08-17T11:52:37+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40073#p40073I don't have a launchpad, so I had to go for the user manual, maybe I didn't look at the good one. send me the exact manual of your own mini launchpad and I try to fix the script
Statistics: Posted by oli_lab — 17 Aug 2018, 12:52
]]>2018-08-17T00:28:10+01:002018-08-17T00:28:10+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40072#p40072Thank you for your patch. I tried it . It doesn't work whith my launchpad (mini) It work only when i select a row by clicking but not with the launchpad directly. It dosen't work too when i recall a preset. Sorry.
Statistics: Posted by joffo78 — 17 Aug 2018, 01:28
]]>2018-08-16T14:54:40+01:002018-08-16T14:54:40+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40070#p40070would be more straight forward to interface if each cells sends consecutive note on.[/s]
Statistics: Posted by oli_lab — 16 Aug 2018, 15:54
]]>2018-08-15T22:55:11+01:002018-08-15T22:55:11+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40067#p40067I made a big patch to communicate with a launchpad in HH here It make absolutly what i want it should do. But in my opinion it take too much cpu because of the redundancy of task. So i wonder if is not possible to make some script to make it lighter. I'm sure it's not complicated at all but i'm not coder. Thanks a lot and hope this patch would be usefull for the community JF
Statistics: Posted by joffo78 — 15 Aug 2018, 23:55
]]>BrainModularBrainModular Users Forum2018-08-18T20:24:41+01:00https://brainmodular.org/forums/app.php/feed/topic/62582018-08-18T20:24:41+01:002018-08-18T20:24:41+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40081#p40081Statistics: Posted by 23fx23 — 18 Aug 2018, 21:24
]]>2018-08-18T18:37:30+01:002018-08-18T18:37:30+01:00https://brainmodular.org/forums/viewtopic.php?t=6258&p=40080#p40080 Not sure it's possible to do that with the actual module
hope this help
