ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2018-05-24T09:20:03+01:00https://brainmodular.org/forums/app.php/feed/topic/62232018-05-24T09:20:03+01:002018-05-24T09:20:03+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39921#p39921Statistics: Posted by nay-seven — 24 May 2018, 10:20
2018-05-24T08:18:16+01:002018-05-24T08:18:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39920#p39920the audio matrix. And send the values coming out from the data matrix to the other parts of the patch.
Statistics: Posted by Gilsornette — 24 May 2018, 09:18
]]>2018-05-23T22:50:25+01:002018-05-23T22:50:25+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39918#p39918if man swap it by the data matrix, it works as expected
]]>2018-05-23T22:11:02+01:002018-05-23T22:11:02+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39917#p39917Statistics: Posted by nay-seven — 23 May 2018, 23:11
]]>2018-05-23T20:50:14+01:002018-05-23T20:50:14+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39915#p39915If I link the quicklink from the display array outlet I don't get the values when clicking on the matrix interface, only those from "external" lemur switches. Or I'd like to get them in both situations. But maybe it's not possible this way
Statistics: Posted by Gilsornette — 23 May 2018, 21:50
]]>2018-05-23T20:25:06+01:002018-05-23T20:25:06+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39914#p39914Statistics: Posted by nay-seven — 23 May 2018, 21:25
]]>2018-05-23T19:54:57+01:002018-05-23T19:54:57+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39913#p39913For instnace, when [lemur osc 2] is on, values are 0,0 (or the previous state)... Or am I supposed to use [cells out] and [array out] from editor? But in this case I will also need a kind of mainswitch.
Statistics: Posted by Gilsornette — 23 May 2018, 20:54
Statistics: Posted by nay-seven — 23 May 2018, 18:58
]]>2018-05-23T16:41:39+01:002018-05-23T16:41:39+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39911#p39911Statistics: Posted by Gilsornette — 23 May 2018, 17:41
]]>2018-05-23T15:18:58+01:002018-05-23T15:18:58+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39910#p39910Statistics: Posted by nay-seven — 23 May 2018, 16:18
]]>2018-05-23T11:08:53+01:002018-05-23T11:08:53+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39909#p39909http://www.sensomusic.org/forums/upload ... emples.pat In the first version when I use a "lemur switch" the output [cells out] has one step delay. The way I found to solve this problem is to switch between a lemur control and a direct mode. But it doesn't satisfy me. Is it more understandable?
Statistics: Posted by Gilsornette — 23 May 2018, 12:08
]]>2018-05-23T08:38:25+01:002018-05-23T08:38:25+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39908#p39908Statistics: Posted by nay-seven — 23 May 2018, 09:38
]]>2018-05-22T21:54:40+01:002018-05-22T21:54:40+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39907#p39907[cells val]? In nomal use they are sent, but on next step.
Statistics: Posted by Gilsornette — 22 May 2018, 22:54
]]>2018-05-22T07:27:07+01:002018-05-22T07:27:07+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39903#p39903Statistics: Posted by Gilsornette — 22 May 2018, 08:27
]]>2018-05-21T21:48:02+01:002018-05-21T21:48:02+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39898#p39898 Download
edit: you can use a strings mix selector module to use several lists.
Statistics: Posted by nay-seven — 21 May 2018, 22:48
]]>2018-05-21T18:53:26+01:002018-05-21T18:53:26+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39897#p39897 I probably miss something in the forums or tutorials but I don't achieve to send lists (arrays) of parameters to a matrix. I have a simple auduio matrix 2 in 2 out, 4 cells and I won't to activate some cells using, some external buttons (OSc or midi). And, I don't find how to send , for instance, 0,1,0,0, to activate the second cell on the first row. Also is it possible to use lists (arrays?) that have multiple parameters by index ; e.g. Index 1 : 64,13, 07, 56, 124, Index 2 : 27,55, 89,114,45, etc...? Thank you
Statistics: Posted by Gilsornette — 21 May 2018, 19:53
]]>BrainModularBrainModular Users Forum2018-05-24T09:20:03+01:00https://brainmodular.org/forums/app.php/feed/topic/62232018-05-24T09:20:03+01:002018-05-24T09:20:03+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39921#p39921Statistics: Posted by nay-seven — 24 May 2018, 10:20
]]>2018-05-24T08:18:16+01:002018-05-24T08:18:16+01:00https://brainmodular.org/forums/viewtopic.php?t=6223&p=39920#p39920the audio matrix. And send the values coming out from the data matrix to the other parts of the patch.
