ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-05-18T19:29:21+01:00 https://brainmodular.org/forums/app.php/feed/topic/6221 2018-05-18T19:29:21+01:00 2018-05-18T19:29:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=6221&p=39893#p39893 <![CDATA[Change number of channels on existing sampler-recorder?]]>
You can also simply drag the same module over the existing one, will turn to red, then ask you the channel number you need.Then you'll only need to recreate the missing inputs/outputs .
Excellent! Thank you!
Statistics: Posted by steevhise — 18 May 2018, 20:29
2018-05-18T09:03:55+01:00 2018-05-18T09:03:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=6221&p=39890#p39890 <![CDATA[Change number of channels on existing sampler-recorder?]]>
oh, that's a very nice tips !
Statistics: Posted by damstraversaz — 18 May 2018, 10:03
2018-05-18T08:06:42+01:00 2018-05-18T08:06:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=6221&p=39889#p39889 <![CDATA[Change number of channels on existing sampler-recorder?]]> Statistics: Posted by nay-seven — 18 May 2018, 09:06
2018-05-18T06:49:39+01:00 2018-05-18T06:49:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6221&p=39888#p39888 <![CDATA[Change number of channels on existing sampler-recorder?]]> What I usually do is using constant modules plugged into the parameters I want not to be lost,
just pull a link from the input you want the value to be saved then choose "constant" in the contextual menu
then recreate the modules
Statistics: Posted by oli_lab — 18 May 2018, 07:49
2018-05-18T05:30:32+01:00 2018-05-18T05:30:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=6221&p=39887#p39887 <![CDATA[Change number of channels on existing sampler-recorder?]]>
thanks,
steev
Statistics: Posted by steevhise — 18 May 2018, 06:30
thanks,
steev
