ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-05-14T20:11:00+01:00 https://brainmodular.org/forums/app.php/feed/topic/6215 2018-05-14T20:11:00+01:00 2018-05-14T20:11:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39876#p39876 <![CDATA[new sampler record mode]]> there is a record pos output on my module, but I'm not sure you'll be able to patch what you need !
Statistics: Posted by oli_lab — 14 May 2018, 21:11
2018-05-14T11:16:13+01:00 2018-05-14T11:16:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39874#p39874 <![CDATA[new sampler record mode]]> Statistics: Posted by joffo78 — 14 May 2018, 12:16
2018-05-14T11:11:04+01:00 2018-05-14T11:11:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39873#p39873 <![CDATA[new sampler record mode]]>
I don't understand what are the avantages between a traditionnal usine sampler.
as I said it is different :
up to 64 loops from the same sample will reduce RAM use
minimal blocksize : when end and start marker are very close you can choose from glitchy to smooth...
Xfade...lofi or interpolated quality...
File uploaded: http://www.sensomusic.org/forums/upload ... 0multi.pat
Statistics: Posted by oli_lab — 14 May 2018, 12:11
2018-05-14T10:51:39+01:00 2018-05-14T10:51:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39872#p39872 <![CDATA[new sampler record mode]]> Statistics: Posted by joffo78 — 14 May 2018, 11:51
2018-05-14T10:26:59+01:00 2018-05-14T10:26:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39870#p39870 <![CDATA[new sampler record mode]]>
very modular and highly tweakable, needs extra patching to make it works to one's taste.
note that if end marker is before start marker, it goes backward
there is a cross fade fonction as well
it can read up to 64 loops of the same sample.
in that case you can choose play mode to get continuous loops or one shot loops that end either at end of shortest one or longuest one.
you can only record samples live, no read from file yet.
File uploaded: http://www.sensomusic.org/forums/upload ... 20mono.pat
Have fun !
Statistics: Posted by oli_lab — 14 May 2018, 11:26
2018-05-13T21:26:20+01:00 2018-05-13T21:26:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39863#p39863 <![CDATA[new sampler record mode]]>
did you try the "sampler Elite" ? :cool:
I found it.
Sorry but i don't understand anything about it.
Statistics: Posted by joffo78 — 13 May 2018, 22:26
2018-05-13T21:19:09+01:00 2018-05-13T21:19:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39861#p39861 <![CDATA[new sampler record mode]]> Statistics: Posted by joffo78 — 13 May 2018, 22:19
2018-05-13T16:16:31+01:00 2018-05-13T16:16:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39856#p39856 <![CDATA[new sampler record mode]]>
Statistics: Posted by oli_lab — 13 May 2018, 17:16
2018-05-13T11:46:10+01:00 2018-05-13T11:46:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39853#p39853 <![CDATA[new sampler record mode]]> Statistics: Posted by joffo78 — 13 May 2018, 12:46
2018-05-13T10:17:00+01:00 2018-05-13T10:17:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39849#p39849 <![CDATA[new sampler record mode]]> Ill try to find solutions. probably in the next major release.
Statistics: Posted by senso — 13 May 2018, 11:17
2018-05-11T22:15:29+01:00 2018-05-11T22:15:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=6215&p=39829#p39829 <![CDATA[new sampler record mode]]> I suppose it's not very easy.
But it would be fantastic if sampler recording could follow the play position, the pitch, the speed and the loop lengh.
Actually, when i'm in overdub mode, if i make a record when i'm in reverse, the new input isn't recorded à the position where the sampler is like a traditional looper.
i suppose that it's a problem to the core of the sampler. So peharps a sampler module dedicated to overddubing would be the solution ( with undo please !!!).
So for my project, i need also a reverse, pitch (eventually stretching) , marker to slicing and of course overdubbing and circular buffer mode.
I notice to when i use sampler in overddubing, it make a lot of click.
I know that this question is not very easy to resolve, and i wonder how the hardware loopers avoid it .
thanks a lot.
JF
Statistics: Posted by joffo78 — 11 May 2018, 23:15
Have fun !
I found it.
thanks a lot.
JF
