ArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-05-13T21:35:50+01:00 https://brainmodular.org/forums/app.php/feed/topic/6213 2018-05-13T21:35:50+01:00 2018-05-13T21:35:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=6213&p=39865#p39865 <![CDATA[2 things lost from upgrade from v2 to v3]]>
(On/Off has to have "saved in preset" enabled.
GREAT!
Statistics: Posted by Pianoscope — 13 May 2018, 22:35
2018-05-13T21:21:37+01:00 2018-05-13T21:21:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=6213&p=39862#p39862 <![CDATA[2 things lost from upgrade from v2 to v3]]>
Thanks for your comments, but not sure I understand this! Are you saying that racks on off state can behaved in a workspace preset as in HH2? What is its "setting"?
Yes its great the grid items can be adjusted individually, but sometimes its hard to select the edge to drag, especially when there are
20+ grid lines. An option or command click might be an answer.
I am basically chasing something for many years now that no software can deliver, only Usine gets the closest. Automating a 60 minute set consisting of 9 or 10 pieces that flow seamlessly into one another, with timeline automation of parameters. Like a modern take of Subotniks "Ghost Box". Each workspace has about 30 racks, and the grid can have about 30 lines, often It gets really hard to manage.
Statistics: Posted by Pianoscope — 13 May 2018, 22:21
2018-05-13T09:29:27+01:00 2018-05-13T09:29:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=6213&p=39843#p39843 <![CDATA[2 things lost from upgrade from v2 to v3]]> 2°) you can adjust line height individually and unlike HH2 make it very big. I think it's better like that ?
Statistics: Posted by senso — 13 May 2018, 10:29
2018-05-11T10:22:26+01:00 2018-05-11T10:22:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=6213&p=39826#p39826 <![CDATA[2 things lost from upgrade from v2 to v3]]>
The grid automation lanes no longer expand when clicked. Dragging to expand the grid lanes is really cumbersome, especially if you have 20+ lanes of automation like I have. Used to work really nicely in v2
any chance of putting these functions back in?
Statistics: Posted by Pianoscope — 11 May 2018, 11:22
GREAT!
