ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-02-12T20:34:29+01:00 https://brainmodular.org/forums/app.php/feed/topic/6116 2018-02-12T20:34:29+01:00 2018-02-12T20:34:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39374#p39374 <![CDATA[how to random start and end positions in sampler]]> Statistics: Posted by Gilsornette — 12 Feb 2018, 20:34
2018-02-12T18:39:14+01:00 2018-02-12T18:39:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39372#p39372 <![CDATA[how to random start and end positions in sampler]]> Statistics: Posted by oli_lab — 12 Feb 2018, 18:39
2018-02-12T18:28:54+01:00 2018-02-12T18:28:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39371#p39371 <![CDATA[how to random start and end positions in sampler]]>
Here is an example patch:
http://www.sensomusic.com/forums/upload ... a_path.jpg
My question is : if I bang button1, what will be the data path?
Object 1 > object 3 > object 2 > object 4
or
object 1 > object 2 > object 3 > object 4
or something else.
What are the data transmission "rules" inside a patch?
I hope you'll understand.
Thank you
Statistics: Posted by Gilsornette — 12 Feb 2018, 18:28
2018-02-11T19:40:58+01:00 2018-02-11T19:40:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39361#p39361 <![CDATA[how to random start and end positions in sampler]]> there is no such a thing in Usine, A change to any input trigger the computing inside the module if the computing is done at callback level or is is done every bloc whatsoever if the computing is done in the onProcess loop
Statistics: Posted by oli_lab — 11 Feb 2018, 19:40
2018-02-11T13:17:15+01:00 2018-02-11T13:17:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39359#p39359 <![CDATA[how to random start and end positions in sampler]]> I've got a question about how Usine transmits datas in a patch. In Max, priority is from right to left and descending order : first object on the right, then the one under, or if not, the one one its left. How does Usine transmits flow datas?
Thank you for all
Statistics: Posted by Gilsornette — 11 Feb 2018, 13:17
2018-02-10T19:20:27+01:00 2018-02-10T19:20:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39354#p39354 <![CDATA[how to random start and end positions in sampler]]>
check it out !
File uploaded: http://www.sensomusic.com/forums/upload ... sample.wkp
Statistics: Posted by oli_lab — 10 Feb 2018, 19:20
2018-02-10T08:03:50+01:00 2018-02-10T08:03:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39348#p39348 <![CDATA[how to random start and end positions in sampler]]> Yes for the extra inlet, and also one when arriving at the end of the sample.
Have a nice day
Gilles
Statistics: Posted by Gilsornette — 10 Feb 2018, 08:03
2018-02-09T23:54:54+01:00 2018-02-09T23:54:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39345#p39345 <![CDATA[how to random start and end positions in sampler]]>
I find it quite unstable because of the way the file duration is calculated (division by 0)
those sampler module would need an extra "file duration" outlet indeed !
Statistics: Posted by oli_lab — 09 Feb 2018, 23:54
2018-02-09T22:58:25+01:00 2018-02-09T22:58:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39344#p39344 <![CDATA[how to random start and end positions in sampler]]> By the way, I understand my mistake regarding the "seq inlet"... sorry..
Statistics: Posted by Gilsornette — 09 Feb 2018, 22:58
2018-02-09T22:40:10+01:00 2018-02-09T22:40:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39343#p39343 <![CDATA[how to random start and end positions in sampler]]> I'll do more work on it...
Statistics: Posted by oli_lab — 09 Feb 2018, 22:40
2018-02-09T21:46:16+01:00 2018-02-09T21:46:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39342#p39342 <![CDATA[how to random start and end positions in sampler]]> What kind of fader do you use? Those I've found have no inlet/outlet "seq" (vertic fader).
But in my case it won't match, for several reasons:
- I want to decrease the length of the sound by moving end position (your example) OR start position; this is why I cannot use restarting. And I'd like to randomize this choice
- I will use sounds of different lengths and I want the "decreasing" going until a duration (in milliseconds) that I'll decide. I'll use [pass] to stop the flow above a certain duration . And so I need a number of steps, depending of the length of the sound, that is variable
I hope that you'll understand my explanations
Statistics: Posted by Gilsornette — 09 Feb 2018, 21:46
2018-02-09T19:39:28+01:00 2018-02-09T19:39:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39341#p39341 <![CDATA[how to random start and end positions in sampler]]>
the fader should be : min set to -10 and max set to 0
Statistics: Posted by oli_lab — 09 Feb 2018, 19:39
2018-02-09T18:17:30+01:00 2018-02-09T18:17:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39340#p39340 <![CDATA[how to random start and end positions in sampler]]> http://www.sensomusic.com/forums/upload ... %20end.pat
Statistics: Posted by Gilsornette — 09 Feb 2018, 18:17
2018-02-09T18:02:27+01:00 2018-02-09T18:02:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39338#p39338 <![CDATA[how to random start and end positions in sampler]]> Statistics: Posted by oli_lab — 09 Feb 2018, 18:02
2018-02-09T17:25:42+01:00 2018-02-09T17:25:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=6116&p=39337#p39337 <![CDATA[how to random start and end positions in sampler]]>
I'm a new user of Usine. I want to do a patch using a sampler that read first a file entirely then on first loop half of the file, on second loop half of the former, and son on. (dividing its length by two at each play).
I have no problem to do it by giving a new position eachtime to the startpoint OR eachtime to the end point.
But if I want to alternate between these 2 options, once moving start point than on next loop moving end point, I' ve got problems.
I'm sending the new « coordinates » each time the player reaches the end of the part of the sample.
First question : to do this I use [A-B], where A is End position and B is Position, and when it's above 0.001, it sends a trigger. Is there another way to « trigger » the end of the sample ? [A-B] + [=0] doesn't seem to work and I cannot use restarting.
(I need the trigger before to send the new start position).
Second question : it acts like if the flow was looping and sending out too quickly the informations to start or end position. I've tried to use [wait] but it doesn't work. Do you have an idea ?
Maybe I'm completely wrong about the way I want to do this...
Statistics: Posted by Gilsornette — 09 Feb 2018, 17:25
or
or something else.
Thank you
Thank you for all
check it out !
Have a nice day
Gilles
