ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2018-02-26T12:40:59+01:00https://brainmodular.org/forums/app.php/feed/topic/61142018-02-26T12:40:59+01:002018-02-26T12:40:59+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39512#p39512Statistics: Posted by x.iso — 26 Feb 2018, 12:40
2018-02-26T11:15:52+01:002018-02-26T11:15:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39507#p39507for now, no real simple solution. be patent senso+++
]]>2018-02-10T07:13:38+01:002018-02-10T07:13:38+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39347#p39347Statistics: Posted by rlgsbt — 10 Feb 2018, 07:13
]]>2018-02-09T11:57:37+01:002018-02-09T11:57:37+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39335#p39335and also record from inputs !
Statistics: Posted by oli_lab — 09 Feb 2018, 11:57
]]>2018-02-09T10:12:55+01:002018-02-09T10:12:55+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39334#p393341) Whatever style was applied to object, if it's gone due to number of objects reduced then it's getting reset after adding back. This breaks some use case scenarios. So properties retaining ability would be good. 2) There's no way to control any XYpad object's parameters externally. A bit sad as well, takes away ability to have more visual feedback on what's going on. 3) can't make centre of object touch the borders of the pad.
It's possible to mitigate 1 and 2 issues by making a patch with container and shapes, mimicking XYpad, but perhaps that should be added to library as alternative to module. as for 3rd problem, the only way for now is to use TouchFader add-on module (which is now included in library), but it lacks some of the XYpad abilities (although have some unique of it's own).
]]>BrainModularBrainModular Users Forum2018-02-26T12:40:59+01:00https://brainmodular.org/forums/app.php/feed/topic/61142018-02-26T12:40:59+01:002018-02-26T12:40:59+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39512#p39512Statistics: Posted by x.iso — 26 Feb 2018, 12:40
]]>2018-02-26T11:15:52+01:002018-02-26T11:15:52+01:00https://brainmodular.org/forums/viewtopic.php?t=6114&p=39507#p39507for now, no real simple solution. be patent senso+++
