ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-12-15T00:37:34+01:00https://brainmodular.org/forums/app.php/feed/topic/60222017-12-15T00:37:34+01:002017-12-15T00:37:34+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38785#p38785Statistics: Posted by woodslanding — 15 Dec 2017, 00:37
2017-12-14T23:04:50+01:002017-12-14T23:04:50+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38778#p38778 Maybe I have the syntax wrong....?
Statistics: Posted by woodslanding — 14 Dec 2017, 23:04
]]>2017-12-14T22:55:57+01:002017-12-14T22:55:57+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38777#p38777 pathstr and searchrec
which do not seem to be supported.... so nothing direct at the moment. I can extract the parent folder portion of each file. Then I'll have a bunch of duplicate folder names in my stringList. Is there a simple way to remove them??
Statistics: Posted by woodslanding — 14 Dec 2017, 22:55
]]>2017-12-14T18:41:19+01:002017-12-14T18:41:19+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38773#p38773Statistics: Posted by woodslanding — 14 Dec 2017, 18:41
]]>2017-12-14T18:35:48+01:002017-12-14T18:35:48+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38772#p38772 I imagined a 'folders' option in the 'file type' drop down for the file lister object, but that doesn't exist....
Statistics: Posted by woodslanding — 14 Dec 2017, 18:35
]]>BrainModularBrainModular Users Forum2017-12-15T00:37:34+01:00https://brainmodular.org/forums/app.php/feed/topic/60222017-12-15T00:37:34+01:002017-12-15T00:37:34+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38785#p38785Statistics: Posted by woodslanding — 15 Dec 2017, 00:37
]]>2017-12-14T23:04:50+01:002017-12-14T23:04:50+01:00https://brainmodular.org/forums/viewtopic.php?t=6022&p=38778#p38778 Maybe I have the syntax wrong....?
