ArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-12-15T10:01:45+02:00https://brainmodular.org/forums/app.php/feed/topic/60202017-12-15T10:01:45+02:002017-12-15T10:01:45+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38787#p38787we finally succeed to reproduce, will be solved in 0154
Statistics: Posted by nay-seven — 15 Dec 2017, 09:01
]]>2017-12-15T01:36:06+02:002017-12-15T01:36:06+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38784#p38784Statistics: Posted by crackle — 15 Dec 2017, 00:36
2017-12-15T01:13:49+02:002017-12-15T01:13:49+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38783#p38783Can you please test what's happen if you drag a sample first ( to create a sampler), then an FX patch ? Test on an existing empty rack , then on an empty space
Statistics: Posted by nay-seven — 15 Dec 2017, 00:13
]]>2017-12-15T01:05:13+02:002017-12-15T01:05:13+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38782#p38782Statistics: Posted by crackle — 15 Dec 2017, 00:05
]]>2017-12-15T01:00:01+02:002017-12-15T01:00:01+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38781#p38781
a precision: you talk about patches from the browser/library tab or from the modules tab ?
The patches under the Library tab won't load the Control Panel into the rack.
I've tried two Mac laptops, both running OSX 10.13.2, and they behave the same. Let me know if I can provide any more info. Thanks.
Statistics: Posted by crackle — 15 Dec 2017, 00:00
]]>2017-12-14T14:14:12+02:002017-12-14T14:14:12+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38769#p38769Statistics: Posted by nay-seven — 14 Dec 2017, 13:14
]]>2017-12-14T11:50:43+02:002017-12-14T11:50:43+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38768#p38768 Btw, for info High Sierra is not officially supported yet. (but here, on an old 2012 Mac Mini, all works fine.)
Statistics: Posted by nay-seven — 14 Dec 2017, 10:50
]]>2017-12-14T06:16:16+02:002017-12-14T06:16:16+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38767#p38767 Watching the tutorials, it appears that adding modules and patches from the Library browser is just a drag-and-drop operation, but that's not what I'm seeing. I've tried reinstalling it and that didn't help things.
I'm on version 3.0.153 on MacOS High Sierra. Thanks for any help or suggestions.
Statistics: Posted by crackle — 14 Dec 2017, 05:16
]]>BrainModularBrainModular Users Forum2017-12-15T10:01:45+02:00https://brainmodular.org/forums/app.php/feed/topic/60202017-12-15T10:01:45+02:002017-12-15T10:01:45+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38787#p38787we finally succeed to reproduce, will be solved in 0154
]]>2017-12-15T01:13:49+02:002017-12-15T01:13:49+02:00https://brainmodular.org/forums/viewtopic.php?t=6020&p=38783#p38783Can you please test what's happen if you drag a sample first ( to create a sampler), then an FX patch ? Test on an existing empty rack , then on an empty space
