ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-12-30T21:12:11+01:00 https://brainmodular.org/forums/app.php/feed/topic/6014 2017-12-30T21:12:11+01:00 2017-12-30T21:12:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38898#p38898 <![CDATA[option to save wkp in dedicated folder with all used components inside]]> By the way, in Live there's just option to save projects in their own folders, so all used samples and midi files are stored there and all versions of the project are stored in that same folder, which is quite handy. That's where the suggestion comes from initially. But even without that option in Live browser you can just peek inside project files and see tracks inside and their midi/audio clips.
Statistics: Posted by x.iso — 30 Dec 2017, 21:12
2017-12-30T18:43:41+01:00 2017-12-30T18:43:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38896#p38896 <![CDATA[option to save wkp in dedicated folder with all used components inside]]>
I'll try to create a wkp parser in futures versions of Usine to have an access of patches of a wkp in the browser.
but probably in HH4?
Statistics: Posted by senso — 30 Dec 2017, 18:43
2017-12-30T17:06:51+01:00 2017-12-30T17:06:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38895#p38895 <![CDATA[option to save wkp in dedicated folder with all used components inside]]> Statistics: Posted by x.iso — 30 Dec 2017, 17:06
2017-12-30T13:10:00+01:00 2017-12-30T13:10:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38886#p38886 <![CDATA[option to save wkp in dedicated folder with all used components inside]]> maybe it does the trick ?
Statistics: Posted by senso — 30 Dec 2017, 13:10
2017-12-09T23:29:37+01:00 2017-12-09T23:29:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38723#p38723 <![CDATA[option to save wkp in dedicated folder with all used components inside]]> Statistics: Posted by x.iso — 09 Dec 2017, 23:29
2017-12-09T21:17:35+01:00 2017-12-09T21:17:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38719#p38719 <![CDATA[option to save wkp in dedicated folder with all used components inside]]>
You can use "export workspace". Hollyhock will create a folder with all used resources (audio, video....). In the past, Hollyhock exported racks and patches too, but not anymore, certainely because it is redondant...
Regards
Statistics: Posted by SylvainT — 09 Dec 2017, 21:17
2017-12-09T16:21:15+01:00 2017-12-09T16:21:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=6014&p=38713#p38713 <![CDATA[option to save wkp in dedicated folder with all used components inside]]> Statistics: Posted by x.iso — 09 Dec 2017, 16:21
Regards
