ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-11-22T02:12:56+02:00https://brainmodular.org/forums/app.php/feed/topic/59792017-11-22T02:12:56+02:002017-11-22T02:12:56+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38573#p38573 So I have the fix for this. I reported it the other day, but the solution. Under settings set full-screen on start-up. If you restart Usine....
The Full-Screen Toggle now works!
Looks like all you have to do is...do this once and it works regardless if you startup in full-screen anymore
-s
Statistics: Posted by sephult — 22 Nov 2017, 01:12
]]>2017-11-21T04:11:43+02:002017-11-21T04:11:43+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38571#p38571Statistics: Posted by 23fx23 — 21 Nov 2017, 03:11
2017-11-19T08:12:14+02:002017-11-19T08:12:14+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38568#p38568Statistics: Posted by gurulogic — 19 Nov 2017, 07:12
]]>2017-11-18T21:58:12+02:002017-11-18T21:58:12+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38567#p38567Glad I am not the only crazy
-s
Statistics: Posted by sephult — 18 Nov 2017, 20:58
]]>2017-11-18T21:47:49+02:002017-11-18T21:47:49+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38566#p38566Statistics: Posted by x.iso — 18 Nov 2017, 20:47
]]>2017-11-18T16:11:37+02:002017-11-18T16:11:37+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38563#p38563When this happens the color palette stops coming up to.
Anyone with x64 ever notice this? At the moment Senso cannot reproduce. I'd appreciate if others took a look.
-s
Statistics: Posted by sephult — 18 Nov 2017, 15:11
]]>BrainModularBrainModular Users Forum2017-11-22T02:12:56+02:00https://brainmodular.org/forums/app.php/feed/topic/59792017-11-22T02:12:56+02:002017-11-22T02:12:56+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38573#p38573 So I have the fix for this. I reported it the other day, but the solution. Under settings set full-screen on start-up. If you restart Usine....
-s
]]>2017-11-19T08:12:14+02:002017-11-19T08:12:14+02:00https://brainmodular.org/forums/viewtopic.php?t=5979&p=38568#p38568Statistics: Posted by gurulogic — 19 Nov 2017, 07:12
-s
-s
