ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-01-02T01:00:55+01:00 https://brainmodular.org/forums/app.php/feed/topic/5957 2018-01-02T01:00:55+01:00 2018-01-02T01:00:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38917#p38917 <![CDATA[Automations - Shift-click to bend the lines into curves]]> Statistics: Posted by x.iso — 02 Jan 2018, 01:00
2017-12-29T18:28:44+01:00 2017-12-29T18:28:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38867#p38867 <![CDATA[Automations - Shift-click to bend the lines into curves]]> Statistics: Posted by senso — 29 Dec 2017, 18:28
2017-11-11T18:55:16+01:00 2017-11-11T18:55:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38512#p38512 <![CDATA[Automations - Shift-click to bend the lines into curves]]>
I think it would be much simpler if automations that currently can be recorded in rack would just record in grid inside rack (so affected rack would appear in grid automatically if not present) instead of those separate automations. and thus no problem with competing automations for same parameters as each section can have different automation takes and even inside section you could have different takes as it is now. and anything should be automated if needed, not just what grid allows currently.
Statistics: Posted by x.iso — 11 Nov 2017, 18:55
2017-11-11T17:58:35+01:00 2017-11-11T17:58:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38511#p38511 <![CDATA[Automations - Shift-click to bend the lines into curves]]> Statistics: Posted by x.iso — 11 Nov 2017, 17:58
2017-11-11T17:43:31+01:00 2017-11-11T17:43:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38510#p38510 <![CDATA[Automations - Shift-click to bend the lines into curves]]> Statistics: Posted by senso — 11 Nov 2017, 17:43
2017-11-11T17:04:47+01:00 2017-11-11T17:04:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38506#p38506 <![CDATA[Automations - Shift-click to bend the lines into curves]]> the lines and steps are closed.
Statistics: Posted by senso — 11 Nov 2017, 17:04
2017-11-08T16:09:52+01:00 2017-11-08T16:09:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=5957&p=38487#p38487 <![CDATA[Automations - Shift-click to bend the lines into curves]]> Statistics: Posted by x.iso — 08 Nov 2017, 16:09
