ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-03-01T17:49:03+01:00 https://brainmodular.org/forums/app.php/feed/topic/593 2008-03-01T17:49:03+01:00 2008-03-01T17:49:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3900#p3900 <![CDATA[VSTs to communicate over LANs]]> so check your installation and take care of your brain....
Statistics: Posted by senso — 01 Mar 2008, 17:49
2008-03-01T16:32:47+01:00 2008-03-01T16:32:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3898#p3898 <![CDATA[VSTs to communicate over LANs]]>
I will be crazy !! I don't understand what is the problem !! I can shared files on the two computers by wifi, it seems to be something IN and OUT in my fire wall, it is the same problem without firewall .....
I need to stop before my brain crash .....
Statistics: Posted by cmodica — 01 Mar 2008, 16:32
2008-02-29T21:35:52+01:00 2008-02-29T21:35:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3886#p3886 <![CDATA[VSTs to communicate over LANs]]>
Waouh !!
that would be nice
time is never fast enought
Statistics: Posted by grego mondo — 29 Feb 2008, 21:35
2008-02-29T21:17:46+01:00 2008-02-29T21:17:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3884#p3884 <![CDATA[VSTs to communicate over LANs]]> But it's better to fill something like /usine/audio1/
and normally you don't have to deal with the IP adr:
- as a server (send osc) Usine sends in 'broadcast' mode by default. It means that all computers connected to the network receive the data's at the same time. you don't need to specify any particular IP except if you want for example send some data's to a computer and other dats's to another computer.
- as a client, Usine take every incoming osc msg from all the computers, Internet etc... Every thing. Except if you specify an IP adr, so usine apply filters to get data's only from this particular computer.
So in a basic "2 computers" network you can forget IP's!
And also it's recommended to use precise IP's on stage: IP are generated dynamically, it means that an adr can change over the time, especially if you switch off a computer for any reason (like a bug).
Ho yes I know usine is supposed to never crash, but we never know...
I forgot, I plan to create a set of modules to be able to play in "Lan Live Sessions" with Usine:
- audio compression/decompression to send audio over the net
- auto synchronization
- etc.
not really a priority but soon I hope.
Statistics: Posted by senso — 29 Feb 2008, 21:17
2008-02-29T20:54:48+01:00 2008-02-29T20:54:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3883#p3883 <![CDATA[VSTs to communicate over LANs]]> lets call your audio flow : audio
address : /audio/
ip : 192.168.1.60 ou 192.168.1.135 (anyway the other computer's IP)
I didn't try to send audio yet, only synchro (tempo, beats per bar, cycle and cycle start) and datas ... in the "Punch In Weird" Adds On, the patch on track 9 is the one I used)
may be it took me too long to answer (had to turn on Usine computer and started writting in french (it took me about five minutes to realize it)
Statistics: Posted by grego mondo — 29 Feb 2008, 20:54
2008-02-29T20:38:26+01:00 2008-02-29T20:38:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3882#p3882 <![CDATA[VSTs to communicate over LANs]]> with usine you don't need to deal with IP adr or ports; they are only available for precises & complex routings
we suppose that computer1 sends and computer2 receives
1)activate osc on both computers
2) on the computer1 take a osc send modulex2 and set the TYPE to array(b)
3) set the osc addr to something like /usine/audio1 or what ever
4) on the computer2 verify that yoy receive osc packets over the lan: open osc setup windows;. Normally it will display osc packets. If nothing hapend on cpt2 it because your lan is not well configured; welcome to the Windows lan setup....
5) on cp2 take a osc receivex2 and the addr to /usine/audio1 (see point 1)
6) data1 data2 outlets sends the audio flows.
that's all!!!
Statistics: Posted by senso — 29 Feb 2008, 20:38
2008-02-29T18:47:32+01:00 2008-02-29T18:47:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=3880#p3880 <![CDATA[VSTs to communicate over LANs]]>
So i conect the audio out from a sampler to OSC SEND data1. On the over computer i connect the OSC receive data1 to Audio Out ..... ????
Is it OK ?
OSC is active on the two computer. One of them has the IP adress 192.168.1.60 and the other one 192.168.1.135. They are connected to my livebox at home.
But No sound transmit ????
Is there any job to do with port number ?
Did someone could explain to me how to do that ?
Thank you
Statistics: Posted by cmodica — 29 Feb 2008, 18:47
2007-10-09T13:19:59+01:00 2007-10-09T13:19:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=2920#p2920 <![CDATA[VSTs to communicate over LANs]]> I have discover a small bug in the transmission of audio data with the osc modules.
Now it works so the osc layer of usine can do a good job for that!
next release
Statistics: Posted by senso — 09 Oct 2007, 14:19
2007-10-09T11:28:58+01:00 2007-10-09T11:28:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=593&p=2919#p2919 <![CDATA[VSTs to communicate over LANs]]> http://www.tuppesoft.com/audiotunnel.html
Statistics: Posted by bsork — 09 Oct 2007, 12:28
Waouh !!
that would be nice
- etc.
address : /audio/
that's all!!!
Is it OK ?
Thank you
next release
