ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-11-28T20:37:27+01:00 https://brainmodular.org/forums/app.php/feed/topic/5927 2017-11-28T20:37:27+01:00 2017-11-28T20:37:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38620#p38620 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> I think it should be able to turn on/off now as well. Before once you adjusted the length you couldn't revert to just normal...
-s
Statistics: Posted by sephult — 28 Nov 2017, 20:37
2017-11-28T14:54:43+01:00 2017-11-28T14:54:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38614#p38614 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> Statistics: Posted by x.iso — 28 Nov 2017, 14:54
2017-11-28T11:02:21+01:00 2017-11-28T11:02:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38610#p38610 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> I ran into the same problems ages ago.
Actually I'd have to dig and convert...but I wrote a buffer script that was dynamic. Was pretty cool but needed some work.
It was essentially the same type of thing, if it didn't recognize in a specified amount of time it would send out the buffered note # corresponding.
(had a really cool dynamic channelizer too...was using for micro tonality project).
I was needing something a while back, hence the new mode suggestions for the transformer.
I haven't had a chance to really dig into the new mode, seemed to work well though.
-s
Statistics: Posted by sephult — 28 Nov 2017, 11:02
2017-11-28T10:48:48+01:00 2017-11-28T10:48:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38608#p38608 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> Statistics: Posted by x.iso — 28 Nov 2017, 10:48
2017-11-02T02:29:55+01:00 2017-11-02T02:29:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38386#p38386 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> if flow is stopped size will be null, so the null output 1, not will ouput 0 and vice versa.
if you need like a pass if change something constantly sending pulese 0..10..1 ect add a toggle out of this that'll make each bloc alternate, ie :
Statistics: Posted by 23fx23 — 02 Nov 2017, 02:29
2017-11-02T02:15:28+01:00 2017-11-02T02:15:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38385#p38385 <![CDATA[how do I set up a limit length for midi output note ON messages?]]>
I've solved the problem with loosing note OFF messages, but the implementation with length limiter would be also interesting.
As for other question, I guess there's no such module? I had some idea for subpatch as such module substitute, I'll share when I get it done.
Statistics: Posted by x.iso — 02 Nov 2017, 02:15
2017-10-28T01:20:59+01:00 2017-10-28T01:20:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38170#p38170 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> Statistics: Posted by x.iso — 28 Oct 2017, 02:20
2017-10-28T00:35:35+01:00 2017-10-28T00:35:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5927&p=38169#p38169 <![CDATA[how do I set up a limit length for midi output note ON messages?]]> http://www.sensomusic.org/forums/viewtopic.php?id=5898
I've stumbled on a problem, that in certain situations some dispatched notes from my sequencer never receive note OFF message, so the note freezes until it's hit with same 'note on' message. I need something to trace all notes and send 'note off' message to those that exceed the limit set by fader or other control. How can I do that?
Statistics: Posted by x.iso — 28 Oct 2017, 01:35
-s
-s
