ArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-10-29T13:00:23+01:00https://brainmodular.org/forums/app.php/feed/topic/59212017-10-29T13:00:23+01:002017-10-29T13:00:23+01:00https://brainmodular.org/forums/viewtopic.php?t=5921&p=38214#p38214Statistics: Posted by x.iso — 29 Oct 2017, 13:00
2017-10-29T09:58:24+01:002017-10-29T09:58:24+01:00https://brainmodular.org/forums/viewtopic.php?t=5921&p=38211#p38211Statistics: Posted by senso — 29 Oct 2017, 09:58
]]>2017-10-25T17:20:09+01:002017-10-25T17:20:09+01:00https://brainmodular.org/forums/viewtopic.php?t=5921&p=38151#p38151 Does anybody remember, there was some dedicated software/touchscreen combo at NAMM a few years back that allowed you to display some small portion of a vst in one of its windows. I thought that was super clever.
usine V5 had lots of options of where to put vst windows IIRC. I found good uses for that.
Statistics: Posted by woodslanding — 25 Oct 2017, 18:20
]]>2017-10-23T18:26:14+01:002017-10-23T18:26:14+01:00https://brainmodular.org/forums/viewtopic.php?t=5921&p=38129#p38129So the options would be as with normal panel elements - target and position, the target would be normal window, floating popup window (that stays in same place relative to the rest of patches and racks as you scroll the workspace), patch or container. Scaling is not so important if it's a big hassle to implement.
Another option is bitmap output of the plugin (with scaling and cropping), with this you don't get to control plugin UI directly, but it can be used to cut-in some portions of plugin's UI into the patch or just use it as reference background to place Usine's controls on top with same layout.
]]>BrainModularBrainModular Users Forum2017-10-29T13:00:23+01:00https://brainmodular.org/forums/app.php/feed/topic/59212017-10-29T13:00:23+01:002017-10-29T13:00:23+01:00https://brainmodular.org/forums/viewtopic.php?t=5921&p=38214#p38214Statistics: Posted by x.iso — 29 Oct 2017, 13:00
]]>2017-10-29T09:58:24+01:002017-10-29T09:58:24+01:00https://brainmodular.org/forums/viewtopic.php?t=5921&p=38211#p38211Statistics: Posted by senso — 29 Oct 2017, 09:58
