ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-10-28T16:15:28+01:00 https://brainmodular.org/forums/app.php/feed/topic/5920 2017-10-28T16:15:28+01:00 2017-10-28T16:15:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38184#p38184 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]>
Cool. Maybe add something like Alt+Click/Tap or Ctrl+Click/Tap to temporarily switch the mode? if using relative that would alternate to absolute and vice versa.
humm.. not sure Alt=rename and ctrl=reset
so impossible
Statistics: Posted by senso — 28 Oct 2017, 17:15
2017-10-28T12:42:34+01:00 2017-10-28T12:42:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38179#p38179 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]> Statistics: Posted by 23fx23 — 28 Oct 2017, 13:42
2017-10-28T12:39:44+01:00 2017-10-28T12:39:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38178#p38178 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]>
hi,
After years (I can be very slow to find solutions...), I have decided to change mouse behavior in Usine.
In the next release 3.0.145, there will be only two modes: relative (by default), and absolute. Can be changed in the mouse tab of fader/knobs settings.
The mouse jump belongs to the past now!
I think it's better like that.
Statistics: Posted by x.iso — 28 Oct 2017, 13:39
2017-10-28T10:53:17+01:00 2017-10-28T10:53:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38175#p38175 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]> Excited to try!
-s
Statistics: Posted by sephult — 28 Oct 2017, 11:53
2017-10-28T10:41:40+01:00 2017-10-28T10:41:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38174#p38174 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]> After years (I can be very slow to find solutions...), I have decided to change mouse behavior in Usine.
Statistics: Posted by senso — 28 Oct 2017, 11:41
2017-10-28T01:38:14+01:00 2017-10-28T01:38:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38171#p38171 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]> I am the same way...lol
:lol:
-s
Statistics: Posted by sephult — 28 Oct 2017, 02:38
2017-10-23T18:55:06+01:00 2017-10-23T18:55:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38131#p38131 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]> Statistics: Posted by 23fx23 — 23 Oct 2017, 19:55
2017-10-23T18:34:08+01:00 2017-10-23T18:34:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38130#p38130 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]>
I have not tried your Touch Fader modules,
I guess I phrased it a bit weird, they're not mine :P 23fx23 made it and some more awesome stuff.
Statistics: Posted by x.iso — 23 Oct 2017, 19:34
2017-10-23T15:58:28+01:00 2017-10-23T15:58:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38118#p38118 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]> A relative fader mode for touch would be most welcome. You rarely want a sudden jump using a fader. I have not tried your Touch Fader modules, but the usual modes for faders are:
1. Relative - the fader movement from current value is relative to where you touched. Disadvantage is your finger might not line up with the slider cursor.
2. Catch - the slider does not move until your finger passes over the cursor, at which point it "catches" and the slider starts to move
3. Smoothed - if you touch away from he cursor it will move to where the finger is, but smoothly according to the smoothing factor, so it does not jump suddenly.
Simon.
Statistics: Posted by sm_jamieson — 23 Oct 2017, 16:58
2017-10-23T14:48:04+01:00 2017-10-23T14:48:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=5920&p=38117#p38117 <![CDATA[Absolute and Relative mode switch for adjusting UI controls]]>
I've solved this problem for now using Touch_Fader add-on, as it does have different behaviour mode switch (absolute, relative, angular) and many more options, but this kind of basic thing should be included in native controls. Ideally, Touch_fader features should be native part of Usine, but it's not available for Mac, so I can't share patches and workspaces for Mac users with confidence that everything will work.
Statistics: Posted by x.iso — 23 Oct 2017, 15:48
so impossible
hi,
-s
:lol:
-s
Simon.
