ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-10-27T11:03:14+01:00https://brainmodular.org/forums/app.php/feed/topic/59182017-10-27T11:03:14+01:002017-10-27T11:03:14+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38155#p38155Statistics: Posted by nay-seven — 27 Oct 2017, 12:03
2017-10-27T10:19:58+01:002017-10-27T10:19:58+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38154#p38154It appears that it was my third-party expansion software wich cause the issue. Regards Eric
]]>2017-10-27T08:41:41+01:002017-10-27T08:41:41+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38153#p38153maybe you have similar issue with Sierra users, have you check the installation page ?
Statistics: Posted by nay-seven — 27 Oct 2017, 09:41
]]>2017-10-27T07:59:12+01:002017-10-27T07:59:12+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38152#p38152 I have download it, but here it is impossible to open the application. I work with Maverick, is it the reason of the issue? Regards E
Statistics: Posted by nay-seven — 23 Oct 2017, 14:02
]]>2017-10-23T12:33:05+01:002017-10-23T12:33:05+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38113#p38113Statistics: Posted by x.iso — 23 Oct 2017, 13:33
]]>2017-10-23T11:13:50+01:002017-10-23T11:13:50+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38112#p38112Install is nearly half the size of previous .app even after updating from previous install. 1.13GB to 663MB. Did you do something to optimise or is something fishy going on?
- Improved ArtNet test in the setup - Implementation of node and sub-net settings in ArtNet engine - MIDI-split (multi split) module - Drop-file-mode option in the sampler - Improved light-direct-dmx and light-direct-artnet modules - Vertical-lock mode on sequenced-steps and array-display modules - Clear-drop-file-name inlet in modules
fixed bugs
- Possible issues if 2 webcam are connected with the same name - Control positions can be lost when a wkp is saved in IB view - Sometime, racks are reloaded with wrong outputs settings - Array-expand doesn't work as expected - Sequenced-points modules is not created properly
3.0.143 3.0.142 3.0.141 intermediate versions
Statistics: Posted by nay-seven — 22 Oct 2017, 21:57
]]>BrainModularBrainModular Users Forum2017-10-27T11:03:14+01:00https://brainmodular.org/forums/app.php/feed/topic/59182017-10-27T11:03:14+01:002017-10-27T11:03:14+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38155#p38155Statistics: Posted by nay-seven — 27 Oct 2017, 12:03
]]>2017-10-27T10:19:58+01:002017-10-27T10:19:58+01:00https://brainmodular.org/forums/viewtopic.php?t=5918&p=38154#p38154It appears that it was my third-party expansion software wich cause the issue. Regards Eric
fixed bugs
