ArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-10-21T17:07:49+01:00https://brainmodular.org/forums/app.php/feed/topic/59142017-10-21T17:07:49+01:002017-10-21T17:07:49+01:00https://brainmodular.org/forums/viewtopic.php?t=5914&p=38100#p38100Statistics: Posted by 23fx23 — 21 Oct 2017, 18:07
2017-10-21T17:00:27+01:002017-10-21T17:00:27+01:00https://brainmodular.org/forums/viewtopic.php?t=5914&p=38098#p38098 I remember with the FastScript I always got hosed because my Min/Max TParameters were limiting my input values.....still in that same mindset.
So good, even though the visuals don't represent the values still are not constrained unless forced to in user-code. Thanks Oli!
Super Awesome as always...looking forward to your latest module library...definitely excited and been lost in the new loopers...
-s
Statistics: Posted by sephult — 21 Oct 2017, 18:00
]]>2017-10-21T16:20:22+01:002017-10-21T16:20:22+01:00https://brainmodular.org/forums/viewtopic.php?t=5914&p=38092#p38092 so it should be ok for your project.
otherwise, if you really don't want the values to be over min max values, use a constrain function and pass all incoming data to it.
"isnan" can help when the result of something you compute is bigger than FLT.
Statistics: Posted by oli_lab — 21 Oct 2017, 17:20
]]>2017-10-21T15:41:41+01:002017-10-21T15:41:41+01:00https://brainmodular.org/forums/viewtopic.php?t=5914&p=38090#p38090 I hope all is well!
So the question and issue I have ran into this morning with the SDK.
Is there a way to Expose the Min/Max and inherit these on the external objects, as well as a separate setting that sets the modules node/internal limits?
Example:
User drags wire from Input A and drops and creates Fader A. Set Min/Max limits cause the Fader to be -100 to 100 If the User however changes the Fader Min/Max to a greater number such as -1000 to 1000, the Input A will still accept this and recognize the values.
At the moment I'm stuck wanting to allow the full range of numbers, but not cast these limits to my faders when created. I am using the (-FLT/FLT) as my pParamInfo-MinValue/MaxValue
Oh such puzzles to solve...loving it and documenting as I go though.
Sephults Dummy Guide for the HollyHock SDK....coming in the near future....hahaha
-s
Statistics: Posted by sephult — 21 Oct 2017, 16:41
]]>BrainModularBrainModular Users Forum2017-10-21T17:07:49+01:00https://brainmodular.org/forums/app.php/feed/topic/59142017-10-21T17:07:49+01:002017-10-21T17:07:49+01:00https://brainmodular.org/forums/viewtopic.php?t=5914&p=38100#p38100Statistics: Posted by 23fx23 — 21 Oct 2017, 18:07
]]>2017-10-21T17:00:27+01:002017-10-21T17:00:27+01:00https://brainmodular.org/forums/viewtopic.php?t=5914&p=38098#p38098 I remember with the FastScript I always got hosed because my Min/Max TParameters were limiting my input values.....still in that same mindset.
-s
Example:
-s
