ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-11-10T01:23:55+02:00 https://brainmodular.org/forums/app.php/feed/topic/5909 2017-11-10T01:23:55+02:00 2017-11-10T01:23:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38497#p38497 <![CDATA[USINE HH3 with sierra]]>
Ok, i'll do it when coming back to high sierra in few weeks.
Thanks a lot.
Statistics: Posted by shamanic bicycle — 10 Nov 2017, 00:23
2017-11-04T14:51:07+02:00 2017-11-04T14:51:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38436#p38436 <![CDATA[USINE HH3 with sierra]]> if you re install it again, try to delete /Resources/devices/DeviceDMX_2.0_01.usr-osx32 in the package,
maybe a fix in 0147
Statistics: Posted by nay-seven — 04 Nov 2017, 13:51
2017-11-04T00:55:19+02:00 2017-11-04T00:55:19+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38425#p38425 <![CDATA[USINE HH3 with sierra]]>
I installed my old os10.9 and works fine now, core audio reappears !
Seams to be the high sierra not working perfectly on my computer.
Statistics: Posted by shamanic bicycle — 03 Nov 2017, 23:55
2017-11-03T16:53:59+02:00 2017-11-03T16:53:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38407#p38407 <![CDATA[USINE HH3 with sierra]]>
This topic was first about Sierra, so i first didn't notice you're talking about High Sierra, but i've made test with 146 and from the folder application, works here.
There's some errrors in the log file, we gone to study this..
Statistics: Posted by nay-seven — 03 Nov 2017, 15:53
2017-11-03T16:14:07+02:00 2017-11-03T16:14:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38406#p38406 <![CDATA[USINE HH3 with sierra]]>
log file
Sorry for this trouble.
Statistics: Posted by shamanic bicycle — 03 Nov 2017, 15:14
2017-11-03T15:45:20+02:00 2017-11-03T15:45:20+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38405#p38405 <![CDATA[USINE HH3 with sierra]]>
Can you send me your log file ( usine/right click/Show Package Contents/logUsine.log)
contact@sensomusic.org
Statistics: Posted by nay-seven — 03 Nov 2017, 14:45
2017-11-03T15:35:05+02:00 2017-11-03T15:35:05+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38404#p38404 <![CDATA[USINE HH3 with sierra]]>
done, new fresh dezip (HH146) and placed into app folder, tried in desktop too, same issue, no core audio founded.
Statistics: Posted by shamanic bicycle — 03 Nov 2017, 14:35
2017-11-03T13:36:56+02:00 2017-11-03T13:36:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38403#p38403 <![CDATA[USINE HH3 with sierra]]> can you please try a new fresh dezip and place the Usine.app directly in the application folder ?
Statistics: Posted by nay-seven — 03 Nov 2017, 12:36
2017-11-03T13:25:56+02:00 2017-11-03T13:25:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38402#p38402 <![CDATA[USINE HH3 with sierra]]> New boot after removing the RogueAmoeba suite has no effect on the core-audio availibily on HH3.
Statistics: Posted by shamanic bicycle — 03 Nov 2017, 12:25
2017-11-03T13:18:15+02:00 2017-11-03T13:18:15+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38401#p38401 <![CDATA[USINE HH3 with sierra]]>
Right, no audio core detected in HH3.
However, core audio is working on my mac, i run perfectly logic pro, internal device is running, the rme ff800 & zoom H6 works fine too.
Just HH3 do not find any core audio.
I'm trying to follow this thread : https://forums.developer.apple.com/thread/86582
Statistics: Posted by shamanic bicycle — 03 Nov 2017, 12:18
2017-11-03T12:37:56+02:00 2017-11-03T12:37:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38400#p38400 <![CDATA[USINE HH3 with sierra]]> how is your Mac preference in the sound tab ?
Statistics: Posted by nay-seven — 03 Nov 2017, 11:37
2017-11-03T12:30:23+02:00 2017-11-03T12:30:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38399#p38399 <![CDATA[USINE HH3 with sierra]]>
Encountering some troubles with HH3 on OSX high sierra, impossible to get an asio on the config panel.
I checked to run HH3 from the desktop but nothing to do, HH3 seems not to find any audio setup.
Since i didn't used usine for 6 months, is there something new to do for getting that audio setup appear in the panel ?
or is it the high sierra compatibility not fine for now ?
Statistics: Posted by shamanic bicycle — 03 Nov 2017, 11:30
2017-10-19T12:23:47+02:00 2017-10-19T12:23:47+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38070#p38070 <![CDATA[USINE HH3 with sierra]]> Thanks
Statistics: Posted by Shintylla — 19 Oct 2017, 12:23
2017-10-19T12:21:02+02:00 2017-10-19T12:21:02+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38069#p38069 <![CDATA[USINE HH3 with sierra]]> Have you try wavtap or soundflower ?
Statistics: Posted by nay-seven — 19 Oct 2017, 12:21
2017-10-19T12:14:57+02:00 2017-10-19T12:14:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38068#p38068 <![CDATA[USINE HH3 with sierra]]> May sorry for the out of topic: will rewire or Link be developed in the future?
Statistics: Posted by Shintylla — 19 Oct 2017, 12:14
2017-10-19T12:06:18+02:00 2017-10-19T12:06:18+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38067#p38067 <![CDATA[USINE HH3 with sierra]]> Yes, Usine 3 works with Sierra and High Sierra, simply move the .app on the desktop or in the application folder, run it again
Statistics: Posted by nay-seven — 19 Oct 2017, 12:06
2017-10-19T11:50:03+02:00 2017-10-19T11:50:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=5909&p=38066#p38066 <![CDATA[USINE HH3 with sierra]]> Thanks
Statistics: Posted by Shintylla — 19 Oct 2017, 11:50
Thanks a lot.
maybe a fix in 0147
log file
