ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-12-14T05:57:07+02:00https://brainmodular.org/forums/app.php/feed/topic/59072017-12-14T05:57:07+02:002017-12-14T05:57:07+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38766#p38766Statistics: Posted by crackle — 14 Dec 2017, 04:57
2017-10-23T20:57:32+02:002017-10-23T20:57:32+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38132#p38132Thank you
Statistics: Posted by cmodica — 23 Oct 2017, 20:57
]]>2017-10-23T19:25:30+02:002017-10-23T19:25:30+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38128#p38128Statistics: Posted by nay-seven — 23 Oct 2017, 19:25
]]>2017-10-23T19:21:47+02:002017-10-23T19:21:47+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38127#p38127 It is a good news for you, but some VST are very usefull for me ... :/
Don't worry, i love to change my abitudes. Thank you.
Statistics: Posted by cmodica — 23 Oct 2017, 19:21
]]>2017-10-23T19:16:40+02:002017-10-23T19:16:40+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38126#p38126good news in a way for us, i know it's not easy about VST, but remember Sierra is quiet new (and still in beta btw) so several VST can have issues
Statistics: Posted by nay-seven — 23 Oct 2017, 19:16
]]>2017-10-23T17:33:13+02:002017-10-23T17:33:13+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38121#p38121 I will try to test but you should be right. It should be a VST problem ... I will try to find witch one. Thank you.
Statistics: Posted by cmodica — 23 Oct 2017, 17:33
]]>2017-10-23T17:09:19+02:002017-10-23T17:09:19+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38120#p38120You use some VST, can you try a new start with a new workspace without VST and test if you have same behavior please ?
Statistics: Posted by nay-seven — 23 Oct 2017, 17:09
]]>2017-10-23T17:02:42+02:002017-10-23T17:02:42+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38119#p38119 now it happens all the time. I can't work on a patch ! it is very boring ...
It is impossible to delete a module or a wire until quit and restart ! And after a few minutes it is the same ... quit and restart ... etc.
So i work with HH2.
It is the same thing after the new update to HH 3.0.144.
Nay, did you find something in the log file ?
Statistics: Posted by cmodica — 23 Oct 2017, 17:02
]]>2017-10-18T12:15:02+02:002017-10-18T12:15:02+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38064#p38064Statistics: Posted by nay-seven — 18 Oct 2017, 12:15
]]>2017-10-18T11:46:59+02:002017-10-18T11:46:59+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38061#p38061 It happens this morning again after 1 hour. Everythink work fine. The connection between the soft and the keyboard is ok exept the Backspace with didn't delete anythink. :/
Statistics: Posted by cmodica — 18 Oct 2017, 11:46
]]>2017-10-18T09:13:11+02:002017-10-18T09:13:11+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38060#p38060 The next time it happens i quit and copy the log file.
Statistics: Posted by cmodica — 18 Oct 2017, 09:13
]]>2017-10-18T08:51:43+02:002017-10-18T08:51:43+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38057#p38057if this happen several times again, can you copy your file LogUsine.log please ?
Statistics: Posted by nay-seven — 18 Oct 2017, 08:51
]]>2017-10-18T08:40:40+02:002017-10-18T08:40:40+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38056#p38056 I'm starting to explore H3. It is very cool and uselfull.
I have a strange issue when i want to delete one or more module in the patch. Generaly it works fine. But suddenly, it is impossible to delete. The bar space didn't turn on the play button etc ... everything works but it is like the keyboard is deconnected ....
I should quit and start again to restore.
It happens 2 times in the afternoon.
(MAC OS 10.12.6 - Hollyhock 3.0.140 - Macbook Pro Retina 2012)
Statistics: Posted by cmodica — 18 Oct 2017, 08:40
]]>BrainModularBrainModular Users Forum2017-12-14T05:57:07+02:00https://brainmodular.org/forums/app.php/feed/topic/59072017-12-14T05:57:07+02:002017-12-14T05:57:07+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38766#p38766Statistics: Posted by crackle — 14 Dec 2017, 04:57
]]>2017-10-23T20:57:32+02:002017-10-23T20:57:32+02:00https://brainmodular.org/forums/viewtopic.php?t=5907&p=38132#p38132Thank you
So i work with HH2.
