ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-10-16T20:05:40+01:00 https://brainmodular.org/forums/app.php/feed/topic/5903 2017-10-16T20:05:40+01:00 2017-10-16T20:05:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=5903&p=38036#p38036 <![CDATA[Remote Record automation]]>
Thank you very much.
Statistics: Posted by cmodica — 16 Oct 2017, 21:05
2017-10-16T19:19:53+01:00 2017-10-16T19:19:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=5903&p=38034#p38034 <![CDATA[Remote Record automation]]>
Statistics: Posted by nay-seven — 16 Oct 2017, 20:19
2017-10-16T19:18:31+01:00 2017-10-16T19:18:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=5903&p=38033#p38033 <![CDATA[Remote Record automation]]> play reverse
play some loop part
create variations/different records with up to 32 different midifiles
Statistics: Posted by nay-seven — 16 Oct 2017, 20:18
2017-10-16T19:14:09+01:00 2017-10-16T19:14:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=5903&p=38032#p38032 <![CDATA[Remote Record automation]]> You told me about this method a few years ago. But i imagined that an easy way was possible in new H3. It seems not.
Is it so hard to implement ?
Statistics: Posted by cmodica — 16 Oct 2017, 20:14
2017-10-16T18:50:43+01:00 2017-10-16T18:50:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=5903&p=38031#p38031 <![CDATA[Remote Record automation]]>
here a method i use sometimes: use the piano roll with a midi filter to dispatch some binds ( or direct link of course)
Statistics: Posted by nay-seven — 16 Oct 2017, 19:50
2017-10-16T17:55:26+01:00 2017-10-16T17:55:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=5903&p=38029#p38029 <![CDATA[Remote Record automation]]>
Is there a way in H3, to record automation with a midi controler ? It works fine with the mouse or TrackPad, but it didn't works with an external midi knob.
( H3 is fantastic. Thank you for that. Every thing is more intuitive and the workflow is realy better.)
Statistics: Posted by cmodica — 16 Oct 2017, 18:55
play some loop part
