ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-10-16T08:59:46+02:00 https://brainmodular.org/forums/app.php/feed/topic/5901 2017-10-16T08:59:46+02:00 2017-10-16T08:59:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38020#p38020 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]> Statistics: Posted by mattmarantz — 16 Oct 2017, 08:59
2017-10-16T08:56:10+02:00 2017-10-16T08:56:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38019#p38019 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]> Statistics: Posted by mattmarantz — 16 Oct 2017, 08:56
2017-10-16T00:57:21+02:00 2017-10-16T00:57:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38016#p38016 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]>
So I've tried it out on 32bit Usine (and 32bit VST). I saw that as soon as I touched any parameter within VST GUI, it would start to flutter like crazy. Changing preset helps to reset them to rest, but what's more, I found that as soon as I added Usine UI control to any parameter, this behaviour stopped and I can change any value without those glitches.
Oh wow, ok cool thanks for looking into this! I don't know what Usine UI control is though. What is that? Do you mean like adding a virtual knob to the desired parameter, and then using the knob to control the parameter value? Or what do you mean? Sorry, I have used Usine quite a bit but I don't know what Usine UI controllers are.... Thanks!
Yes, I mean virtual controls (knobs, faders etc) that appear in Usine's User Interface.
Statistics: Posted by x.iso — 16 Oct 2017, 00:57
2017-10-16T00:48:27+02:00 2017-10-16T00:48:27+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38015#p38015 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]>
Statistics: Posted by mattmarantz — 16 Oct 2017, 00:48
2017-10-15T16:16:28+02:00 2017-10-15T16:16:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38013#p38013 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]> Statistics: Posted by x.iso — 15 Oct 2017, 16:16
2017-10-15T15:18:09+02:00 2017-10-15T15:18:09+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38012#p38012 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]>
Hi. Have you selected hardware acceleration in general settings? It's been added just recently in version 3.0.139
Also you need to go to Nvidia control panel and add Usine in 3D settings, then set it to use discrete GPU instead of integrated.
None of that GPU/hardware acceleration stuff worked, and correction: It is not related to MIDI breath. The issue is intermittent unrelated to MIDI Breath. What a bummer.
Hmmm...
So you turned on hardware acceleration and made sure it's using your Nvidia card? Problem also occurs without hardware acceleration on?
I'll try that VST and see how it works on my laptop.
Statistics: Posted by x.iso — 15 Oct 2017, 15:18
2017-10-15T12:25:56+02:00 2017-10-15T12:25:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38011#p38011 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]>
Hmmm...
Statistics: Posted by mattmarantz — 15 Oct 2017, 12:25
2017-10-15T12:15:31+02:00 2017-10-15T12:15:31+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38010#p38010 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]>
Thank you. Let me also add that it appears to be completely related to the use of MIDI Breath. If Breath CC#2 is turned on at all, you get the problem. If MIDI Breath is not turn on on my controller, the problem does not occur.
I suppose I could use Aftertouch instead of CC#2 Breath to control things from my breath controller, but a lot of my patches are already setup with CC#2 in mind.
I will try your suggestions and report back, soon. Thank you.
Statistics: Posted by mattmarantz — 15 Oct 2017, 12:15
2017-10-15T12:11:51+02:00 2017-10-15T12:11:51+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38009#p38009 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]> Also you need to go to Nvidia control panel and add Usine in 3D settings, then set it to use discrete GPU instead of integrated.
Statistics: Posted by x.iso — 15 Oct 2017, 12:11
2017-10-15T12:00:31+02:00 2017-10-15T12:00:31+02:00 https://brainmodular.org/forums/viewtopic.php?t=5901&p=38008#p38008 <![CDATA[Dune 2 stuttering when editing the patches, powerful GPU]]>
I could edit patches in Reaper, save them, and open them in HH3, but that seems silly...
I have a Nvidia 1080 ti, the most powerful GPU currently. It can handle anything so it should be able to handle this!
I have heard that the problem could be that Usine has not selected the 1080ti. I canot find a place to change that though.
What does this issue sound like to you guys? Has anyone else experienced this?
Matt
Statistics: Posted by mattmarantz — 15 Oct 2017, 12:00
Hmmm...
Hmmm...
Matt
