ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2007-12-03T21:07:17+01:00https://brainmodular.org/forums/app.php/feed/topic/5902007-12-03T21:07:17+01:002007-12-03T21:07:17+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3398#p3398Statistics: Posted by jean-mi — 03 Dec 2007, 21:07
2007-12-02T21:49:52+01:002007-12-02T21:49:52+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3383#p3383 There's also nothing wrong with mixing diferent types of sound (re)generation: Eg., the GrooveBoxMixer wkp in the add-ons is a three-channel rhythm box with a "normal" sampler, a grain sampler, and a VSTi.
]]>2007-12-02T16:41:43+01:002007-12-02T16:41:43+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3381#p3381by the way, a midi version of the beatbox, would be nice as well caus' I like its interface a lot, but for obscure reasons, I prefer synths over samples.
Statistics: Posted by jean-mi — 02 Dec 2007, 16:41
]]>2007-11-29T23:02:11+01:002007-11-29T23:02:11+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3363#p3363I didn't even have time to play with the echoplexx yet. Anyway thanks for your comments, they sure helped me to feel better oriented!
Statistics: Posted by jean-mi — 29 Nov 2007, 23:02
]]>2007-11-29T18:47:04+01:002007-11-29T18:47:04+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3349#p3349 Cause it seems to me that with echoplexx, once you have recorded the base layer, you can punch in the other layers anywhere and add short little overdubs and they will still loop back where you placed them over the base layer.
]]>2007-11-29T18:40:11+01:002007-11-29T18:40:11+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3348#p3348Statistics: Posted by eimhin — 29 Nov 2007, 18:40
]]>2007-11-29T18:14:48+01:002007-11-29T18:14:48+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3347#p3347maybe it needs something there to calculate a signature and a number of bars, and set Usine master sync according to the results, and switch to "cycle" sync mode....
Statistics: Posted by jean-mi — 29 Nov 2007, 18:14
]]>2007-11-29T17:48:08+01:002007-11-29T17:48:08+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3344#p3344Statistics: Posted by joojoo1234 — 29 Nov 2007, 17:48
]]>2007-11-29T17:10:34+01:002007-11-29T17:10:34+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3343#p3343Statistics: Posted by jean-mi — 29 Nov 2007, 17:10
]]>2007-11-29T16:51:24+01:002007-11-29T16:51:24+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3342#p3342 I haven't played with Punch-In Midi patch too much yet, but as far as i know you can record for an unlimited amount of time, and then hit the record button again to stop recording and start playback.
]]>2007-11-29T16:10:50+01:002007-11-29T16:10:50+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3339#p3339What I want to do is this: Select a midi channel, play a phraze without knowing in advance where it's gonna stop, then decide it's got to repeat from here and press the "repeat" pedal , and have it repeated from there. After that, repeat this operation to record other phrazes with different sounds on top of this first base-loop I'm OK to use as much piano rolls than I need midi channels, but it seems to me that if I don't synchronise the piano roll with the master usine cycle, at one moment the piano roll is gonna return to its start point as soon as I hit the record button again to record the second layer, even if the first recorded loop was half-finished playing. So there is gonna be a break in the musical flow. Another problem I encounter : when I synchronise the piano roll with usine master cycle, there is no return to the start-point anymore when I hit the record button for the second layer (which is good for me...)...BUT, then, I've got to wait untill the next cycle begins to be able to record, really. And I would like to be able to get instantly from "just play on top, that doesn't record" to "record now and it's gonna be repeated on the next cycle". I'm really sorry if I remain unclear, and anyway I'm gonna dig it again, maybe the "punch-in workspace", in the add-ons, is gonna solve some of these,I don't know. But thanks again.
Statistics: Posted by jean-mi — 29 Nov 2007, 16:10
]]>2007-11-29T08:43:42+01:002007-11-29T08:43:42+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3331#p3331 I don't quite get it as to how you want to operate, but if you browse through the included examples and various add-ons, I'm sure you'll get some ideas as to how you want your setup to function. Recording and controlling/manipulating loops (both audio and midi) can be done in many different ways with Usine, so if you can give a good description of what you're after, I'm sure we can help you here on the forum.
]]>2007-11-28T23:06:48+01:002007-11-28T23:06:48+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3328#p3328Iwant to use it synced with some audio loopers for my guitar, so i don't want the midi loop to return to its start point each time I start a midi overdub. and if possible I would like not to have to decide the length of the midi phraze i'm gonna loop before i actually play it with my midi guitar. It seems verytricky to me at the moment. Could some body get me started? Thanks to every one in this forum
Statistics: Posted by jean-mi — 28 Nov 2007, 23:06
]]>2007-11-25T17:46:35+01:002007-11-25T17:46:35+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3270#p3270Statistics: Posted by joojoo1234 — 25 Nov 2007, 17:46
]]>2007-10-13T15:46:27+01:002007-10-13T15:46:27+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=2961#p2961Statistics: Posted by Newbie Brad — 13 Oct 2007, 16:46
]]>2007-10-13T07:20:55+01:002007-10-13T07:20:55+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=2947#p2947If you can't wait a simple tip: a [CTRL] mouse move on a step resets its value to 0. can help!
]]>2007-10-12T21:11:32+01:002007-10-12T21:11:32+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=2944#p2944Statistics: Posted by Newbie Brad — 12 Oct 2007, 22:11
]]>2007-10-12T15:54:56+01:002007-10-12T15:54:56+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=2942#p2942something like a reset btn? (for example set all pitch values to 0)
]]>2007-10-12T15:06:04+01:002007-10-12T15:06:04+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=2939#p2939Statistics: Posted by Newbie Brad — 12 Oct 2007, 16:06
]]>2007-10-08T17:26:17+01:002007-10-08T17:26:17+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=2907#p2907 Just a question What can I improve in the livepack and what kind of patches should I add? any ideas?
]]>BrainModularBrainModular Users Forum2007-12-03T21:07:17+01:00https://brainmodular.org/forums/app.php/feed/topic/5902007-12-03T21:07:17+01:002007-12-03T21:07:17+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3398#p3398Statistics: Posted by jean-mi — 03 Dec 2007, 21:07
]]>2007-12-02T21:49:52+01:002007-12-02T21:49:52+01:00https://brainmodular.org/forums/viewtopic.php?t=590&p=3383#p3383 There's also nothing wrong with mixing diferent types of sound (re)generation: Eg., the GrooveBoxMixer wkp in the add-ons is a three-channel rhythm box with a "normal" sampler, a grain sampler, and a VSTi.
