ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-12-05T18:00:50+01:00 https://brainmodular.org/forums/app.php/feed/topic/5898 2018-12-05T18:00:50+01:00 2018-12-05T18:00:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=40508#p40508 <![CDATA[MIDI ReSEQ patch]]>
changed line light up behaviour once again, now they stay light up (although dimmed from initial trigger) if note is held and fade once note-off gets to that line.
Statistics: Posted by x.iso — 05 Dec 2018, 18:00
2018-11-08T15:34:03+01:00 2018-11-08T15:34:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=40350#p40350 <![CDATA[MIDI ReSEQ patch]]> Statistics: Posted by x.iso — 08 Nov 2018, 15:34
2017-11-22T00:00:32+01:00 2017-11-22T00:00:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38572#p38572 <![CDATA[MIDI ReSEQ patch]]>
With these tools you can modulate your sequences and melodies (or just one) and spread them to your instruments.
Statistics: Posted by x.iso — 22 Nov 2017, 00:00
2017-10-29T22:58:01+01:00 2017-10-29T22:58:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38216#p38216 <![CDATA[MIDI ReSEQ patch]]> Depending on what you were feeding into this patch it may have been almost unusable, sorry about that.
When HH3.0.145 hits, I'll work on adding range fader to change background sections sizes.
Statistics: Posted by x.iso — 29 Oct 2017, 22:58
2017-10-16T19:44:33+01:00 2017-10-16T19:44:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38035#p38035 <![CDATA[MIDI ReSEQ patch]]>
UPD: reuploaded with different mute switches that work better, additionally with draw mode switch and some UI tweaks.
Statistics: Posted by x.iso — 16 Oct 2017, 20:44
2017-10-16T18:08:07+01:00 2017-10-16T18:08:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38030#p38030 <![CDATA[MIDI ReSEQ patch]]> - touch and drag cell to make double/triple/quadruple note, not sure how to do it though, at least in terms of visualisation. There's a fader mode for matrix, but I want it to activate cell on simple tap/click and then change modes on dragging up/down. any ideas on that? at the very least I could make such setting for each whole row.
- if idea above works, then there'll be a curve setting for velocity falloff
- note length modulation
- step freezing
Statistics: Posted by x.iso — 16 Oct 2017, 19:08
2017-10-16T17:08:19+01:00 2017-10-16T17:08:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38028#p38028 <![CDATA[MIDI ReSEQ patch]]> Statistics: Posted by nay-seven — 16 Oct 2017, 18:08
2017-10-16T16:35:37+01:00 2017-10-16T16:35:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38027#p38027 <![CDATA[MIDI ReSEQ patch]]> Statistics: Posted by x.iso — 16 Oct 2017, 17:35
2017-10-16T12:19:42+01:00 2017-10-16T12:19:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38026#p38026 <![CDATA[MIDI ReSEQ patch]]>
I have some ideas for improvement of this sequencer/midi matrix, like adding buttons for muting whole channels (would be useful for live performance). Also need to replace touch_fader with normal one, since it's a compatibility issue for macs. And perhaps it makes sense to integrate MIDI bus with text input for naming.
Statistics: Posted by x.iso — 16 Oct 2017, 13:19
2017-10-16T11:24:56+01:00 2017-10-16T11:24:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38025#p38025 <![CDATA[MIDI ReSEQ patch]]>
-s
Statistics: Posted by sephult — 16 Oct 2017, 12:24
2017-10-16T11:21:06+01:00 2017-10-16T11:21:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38024#p38024 <![CDATA[MIDI ReSEQ patch]]> Statistics: Posted by sephult — 16 Oct 2017, 12:21
2017-10-16T11:14:30+01:00 2017-10-16T11:14:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38022#p38022 <![CDATA[MIDI ReSEQ patch]]> I am probably going to patch in MIDI Busses and use internal VST.
I do this sometimes with my sequencers and give the option. Create a bus for each output.
Then on each VST you can just wire the input from the bus wirelessly...rack to rack.
-s
Statistics: Posted by sephult — 16 Oct 2017, 12:14
2017-10-14T18:55:15+01:00 2017-10-14T18:55:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=38005#p38005 <![CDATA[MIDI ReSEQ patch]]> Statistics: Posted by gurulogic — 14 Oct 2017, 19:55
2017-10-14T01:01:23+01:00 2017-10-14T01:01:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=5898&p=37995#p37995 <![CDATA[MIDI ReSEQ patch]]> Image
The point of this patch is to split incoming MIDI source notes into separate channels for each, and then remix/remap the whole thing with it's own sequencer basically. So you can get your melody to also trigger drums or use multiple instruments, or both.
Take note that you have to set up your instruments/samplers or devices to receive designated channel from 1 to 12. Set the name of the output bus in settings of the patch, then input that bus in your rack or patch with a channel filter.
[s]This patch uses Touch fader add-on, I'll try to make a version without resorting to that (since this add-on doesn't work on Mac AFAIK), but I couldn't get normal fader to behave in same manner.
[/s]
Also, let me know if images don't show up in patch, but I used standard ones from Usine itself.
UPDATE: v1.1, added channel mute switches, removed touch_fader add-on dependency, added MIDI IN/OUT bus settings and more customization settings into popup window.
UPDATE: v.1.2, fixed 'freezed' notes problem, where in certain conditions note OFF messages would not get through to intended channels, also fixed line light up bug, previously it would react on note OFF messages as well, now only on note ON. also added option for panic trigger on step fader change.
UPDATE: v.1.4, changed the way light triggers to avoid any mistakes, replaced ability to name 3 sections with range fader adjusted optional segments. no names, but otherwise more flexibility. added numbers for mute channel buttons.
Also added simplified version called MIDIReGate v1, outputs just one channel, basically works as gate that is not synced to the clock, but is progressing with incoming notes. condensed UI makes this a useful tool for adding rhythmic complexity to monotone step sequencer's output.
MIDIReSEQ 1.4 http://www.sensomusic.org/forums/uploads.php?file=MidiReSeq_v1_4_hh3.pat
MIDIReGate 1.0 http://www.sensomusic.org/forums/uploads.php?file=midiregate_v1.pat
Statistics: Posted by x.iso — 14 Oct 2017, 02:01
- step freezing
-s
-s
[/s]
