Unfortunately it's an hard job... and 32 bit VST seems to disappear slowly but surely?
sadly, there are many useful old VST's that will never be updated. let alone get 64bit version. I tried Metaplugin, but it's a bit of a hassle to use and almost a nightmare to adapt whole workspace packed with old and 32bit VST's to 64bit Usine.
]]>2017-10-27T16:59:17+01:002017-10-27T16:59:17+01:00https://brainmodular.org/forums/viewtopic.php?t=5878&p=38161#p38161 For exemple, I'm now using most of time the 64 bit version of usine, but all my previous projects are with the 32 bits. I often need to use a rack or a patch from another project, But without 32/64 bit compatibility, most of time you need to repatch the all thing, or find an alternative vst if there is no solution with the native modules. There is too some very useful 32 bit vst only. Reaper is perfect for this, with a native bridge, a sort of "plug and play' feature. These is not a Usine issue, as most of the DAW are working like this, But If Usine could have this feature like reaper, It will be even more different and better than all the others.
DDFM metaplugin is really useful, and a lot more easier to use than jbridge.
Statistics: Posted by damstraversaz — 27 Oct 2017, 17:59
]]>2017-10-27T15:08:32+01:002017-10-27T15:08:32+01:00https://brainmodular.org/forums/viewtopic.php?t=5878&p=38159#p38159Statistics: Posted by senso — 27 Oct 2017, 16:08
2017-10-12T09:22:02+01:002017-10-12T09:22:02+01:00https://brainmodular.org/forums/viewtopic.php?t=5878&p=37984#p37984Statistics: Posted by iococoi — 12 Oct 2017, 10:22
]]>2017-10-12T08:22:28+01:002017-10-12T08:22:28+01:00https://brainmodular.org/forums/viewtopic.php?t=5878&p=37983#p37983 probably this is a good start
"This is a bridge to run Windows VST plugins (both 32 and 64 bits) with Linux VST hosts."
So if it can make use of 32 and 64 bits plugins in linux, there is some part of code which can be used in Hollyhock's VST wrapper to load both 64 and 32 bit plugins
]]>2017-10-12T09:22:02+01:002017-10-12T09:22:02+01:00https://brainmodular.org/forums/viewtopic.php?t=5878&p=37984#p37984Statistics: Posted by iococoi — 12 Oct 2017, 10:22
