ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-10-06T11:20:05+01:00 https://brainmodular.org/forums/app.php/feed/topic/5876 2017-10-06T11:20:05+01:00 2017-10-06T11:20:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37936#p37936 <![CDATA[Usine Hollyhock 3.0.139 update]]> uiii
Statistics: Posted by drakh — 06 Oct 2017, 12:20
2017-10-04T10:11:48+01:00 2017-10-04T10:11:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37927#p37927 <![CDATA[Usine Hollyhock 3.0.139 update]]> Statistics: Posted by sephult — 04 Oct 2017, 11:11
2017-10-01T21:11:23+01:00 2017-10-01T21:11:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37913#p37913 <![CDATA[Usine Hollyhock 3.0.139 update]]>
Damn the unload user dll works as a charm, so much gain time :)
yesss !
Statistics: Posted by oli_lab — 01 Oct 2017, 22:11
2017-09-29T20:51:21+01:00 2017-09-29T20:51:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37901#p37901 <![CDATA[Usine Hollyhock 3.0.139 update]]>
Also had sluggish ui sometimes, now with HW accell pof fast AF back
i was remaining on hh2 cause of this, now time to move on HH3 :)
rockssss!
Statistics: Posted by 23fx23 — 29 Sep 2017, 21:51
2017-09-28T11:17:31+01:00 2017-09-28T11:17:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37895#p37895 <![CDATA[Usine Hollyhock 3.0.139 update]]> Statistics: Posted by sm_jamieson — 28 Sep 2017, 12:17
2017-09-26T11:30:29+01:00 2017-09-26T11:30:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37884#p37884 <![CDATA[Usine Hollyhock 3.0.139 update]]> Statistics: Posted by x.iso — 26 Sep 2017, 12:30
2017-09-26T10:10:10+01:00 2017-09-26T10:10:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37882#p37882 <![CDATA[Usine Hollyhock 3.0.139 update]]> Statistics: Posted by x.iso — 26 Sep 2017, 11:10
2017-09-26T09:18:42+01:00 2017-09-26T09:18:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37879#p37879 <![CDATA[Usine Hollyhock 3.0.139 update]]> Statistics: Posted by 23fx23 — 26 Sep 2017, 10:18
2017-09-26T09:11:14+01:00 2017-09-26T09:11:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=5876&p=37878#p37878 <![CDATA[Usine Hollyhock 3.0.139 update]]>
improvements
- flow-Is-NULL module
- array-limit-size module
- improvement of the MIDI trace on wires
- more accurate [shift+mouse move] on integer faders
- presets can now be renamed by [alt+click] on the preset panel
- user Modules are unloaded after destruction
- length mode option in MIDI-transformer module
- possible font name for values and captions
- improved error trace messages for patches
- use hardware acceleration option reintroduced
- zero pad option in array-extract
- disable-hidden-strings option in the setup/expert
fixed bugs
- MIDI in device patches not plugged correctly
- invalid number of colors in matrix modules
Statistics: Posted by nay-seven — 26 Sep 2017, 10:11
yesss !
rockssss!
improvements
fixed bugs
