ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-12-04T14:52:36+01:00 https://brainmodular.org/forums/app.php/feed/topic/5852 2017-12-04T14:52:36+01:00 2017-12-04T14:52:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38683#p38683 <![CDATA[Apc GrooveBox XL]]>
to be sure :
new: create a new preset with current parameters.
write: write or overwrite the current preset in 1 Clic.
rewrite : need 2 clics, one to activate the rewrite, then clic on the preset number you want rewrite.
Statistics: Posted by nay-seven — 04 Dec 2017, 14:52
2017-12-03T02:26:29+01:00 2017-12-03T02:26:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38667#p38667 <![CDATA[Apc GrooveBox XL]]>
I've found a bug with the APC Groove who is very inconvenient.
But maybe it is not a bug.
Maybe it's just something i've missed.
It is about the presets.
When i work and i write on a preset the APC Groove XL create either a new preset or come to the preset n° 1 and erase your work ...
But don't write on a preset who is working on.
Sometimes it works but it's one of a hundreds.
Because the manipulation is really inconvenient at the end when you work you don't follow it.
Either you loose your work in the process, or you finish your session with 100 prsets or more...
Can you help on this ?
Statistics: Posted by thomaschamotte — 03 Dec 2017, 02:26
2017-11-08T11:07:07+01:00 2017-11-08T11:07:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38486#p38486 <![CDATA[Apc GrooveBox XL]]> for the size, i've improve it, B=86 correspond to the red button where you change length sequence
here 2 patches , one for each channel, all midi learn done
Download
Statistics: Posted by nay-seven — 08 Nov 2017, 11:07
2017-11-07T03:07:55+01:00 2017-11-07T03:07:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38482#p38482 <![CDATA[Apc GrooveBox XL]]>
When you change a value of a note with the velocity button.
- If you use the Shift button with the volume button
The volume automatically take the same value of the last velocity value.
So when you play and choose a value, and after use de main volume you can be surprised...
Statistics: Posted by thomaschamotte — 07 Nov 2017, 03:07
2017-11-07T01:57:02+01:00 2017-11-07T01:57:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38481#p38481 <![CDATA[Apc GrooveBox XL]]> It works very well.
But there is something else who doesn't work and i can't figure it out...
The "Size" sub patch put out the good values of the APC Notes, but the "Fader" module receive nothing.
I don't understand the A=B B=86 in the Size subpatch...
Statistics: Posted by thomaschamotte — 07 Nov 2017, 01:57
2017-11-07T00:03:25+01:00 2017-11-07T00:03:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38480#p38480 <![CDATA[Apc GrooveBox XL]]> here maybe a solution, velocity is in direct mode , other are in midi learn (no need to change it on your side)
2 different patches, named respectively chan 2 and chan 3
test it
Download
Statistics: Posted by nay-seven — 07 Nov 2017, 00:03
2017-11-04T00:32:48+01:00 2017-11-04T00:32:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38432#p38432 <![CDATA[Apc GrooveBox XL]]>
See you.
Statistics: Posted by thomaschamotte — 04 Nov 2017, 00:32
2017-11-04T00:31:38+01:00 2017-11-04T00:31:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38431#p38431 <![CDATA[Apc GrooveBox XL]]> but tomorrow ;-)
Statistics: Posted by nay-seven — 04 Nov 2017, 00:31
2017-11-04T00:03:37+01:00 2017-11-04T00:03:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38428#p38428 <![CDATA[Apc GrooveBox XL]]> So it is not confortable too...
Statistics: Posted by thomaschamotte — 04 Nov 2017, 00:03
2017-11-03T23:59:00+01:00 2017-11-03T23:59:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38426#p38426 <![CDATA[Apc GrooveBox XL]]> Because if the Shift Button is on absolut the default position is the "Start position" and not the pitch.
When the shift is off, the channel is 0 and control the start position
When the Shift is on, the channel is 2 and control the pitch.
But it is not confortable.
Statistics: Posted by thomaschamotte — 03 Nov 2017, 23:59
2017-11-03T23:49:55+01:00 2017-11-03T23:49:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38424#p38424 <![CDATA[Apc GrooveBox XL]]> I'm doing the same thing with the channel 3 of the other APC.
Statistics: Posted by thomaschamotte — 03 Nov 2017, 23:49
2017-11-03T23:43:48+01:00 2017-11-03T23:43:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38423#p38423 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by nay-seven — 03 Nov 2017, 23:43
2017-11-03T23:42:48+01:00 2017-11-03T23:42:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38422#p38422 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by nay-seven — 03 Nov 2017, 23:42
2017-11-03T23:40:10+01:00 2017-11-03T23:40:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38421#p38421 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by nay-seven — 03 Nov 2017, 23:40
2017-11-03T23:35:53+01:00 2017-11-03T23:35:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38420#p38420 <![CDATA[Apc GrooveBox XL]]> In the seq sub patch there is the Knob X who control the pitch. And the Knob Y control the gain.
Because a X+1 module come in the Knob X module, the midi learn doesn't work on an other channel than the 1.
Statistics: Posted by thomaschamotte — 03 Nov 2017, 23:35
2017-11-03T23:31:40+01:00 2017-11-03T23:31:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38419#p38419 <![CDATA[Apc GrooveBox XL]]> do you mean the shift+ first fader dont change sample position when you have 2 instances ?
Statistics: Posted by nay-seven — 03 Nov 2017, 23:31
2017-11-03T23:31:06+01:00 2017-11-03T23:31:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38418#p38418 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by thomaschamotte — 03 Nov 2017, 23:31
2017-11-03T23:17:36+01:00 2017-11-03T23:17:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38417#p38417 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by thomaschamotte — 03 Nov 2017, 23:17
2017-11-03T22:42:38+01:00 2017-11-03T22:42:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38415#p38415 <![CDATA[Apc GrooveBox XL]]>
I just trie your new patch with the velocity directly connected.
It's working very well.
Statistics: Posted by thomaschamotte — 03 Nov 2017, 22:42
2017-11-01T10:29:49+01:00 2017-11-01T10:29:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38367#p38367 <![CDATA[Apc GrooveBox XL]]> try it and tell me if it's work for you and specially with 2 apc instances:
Download
Statistics: Posted by nay-seven — 01 Nov 2017, 10:29
2017-10-31T23:13:13+01:00 2017-10-31T23:13:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38259#p38259 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by nay-seven — 31 Oct 2017, 23:13
2017-10-31T23:04:10+01:00 2017-10-31T23:04:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38258#p38258 <![CDATA[Apc GrooveBox XL]]> Statistics: Posted by thomaschamotte — 31 Oct 2017, 23:04
2017-10-31T23:03:37+01:00 2017-10-31T23:03:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38257#p38257 <![CDATA[Apc GrooveBox XL]]> Image
Statistics: Posted by nay-seven — 31 Oct 2017, 23:03
2017-10-31T22:15:34+01:00 2017-10-31T22:15:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38254#p38254 <![CDATA[Apc GrooveBox XL]]>
I understand what you mean.
I have followed every steps of your post and it doesn't work.
Statistics: Posted by thomaschamotte — 31 Oct 2017, 22:15
2017-10-31T21:20:35+01:00 2017-10-31T21:20:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5852&p=38253#p38253 <![CDATA[Apc GrooveBox XL]]> check this page
About your problem, you have to understand that even if you modify the midi channel in the rack input, when you create a midi learn, Usine will use the real device anyway ( in this case always channel 1)
so there 's a module to solve this , its the midi output to Usine module ( find it in modules/input/otput/additionnal)
add it after your first MIDI input in the main patch:
this way your MIDI learn will be receive on the good channel
Now you need to modify the invisible knob you found for velocity:
tell me if it's ok for you
Statistics: Posted by nay-seven — 31 Oct 2017, 21:20
to be sure :
Download
test it
Download
See you.
Download
