ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-09-10T23:16:07+02:00 https://brainmodular.org/forums/app.php/feed/topic/5848 2017-09-10T23:16:07+02:00 2017-09-10T23:16:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37743#p37743 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> Thank you.
Statistics: Posted by thomaschamotte — 10 Sep 2017, 23:16
2017-09-10T22:55:38+02:00 2017-09-10T22:55:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37741#p37741 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> Statistics: Posted by nay-seven — 10 Sep 2017, 22:55
2017-09-10T22:27:29+02:00 2017-09-10T22:27:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37738#p37738 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
I'm trying to creat a rec mode with your Apc groove.
A rec mode in the Show list.
I don't want to transform the samplers to sampler_rec i just want to add 4 sampler_Rec.
This is the way :
1 - i created a Apc Folder in Usine package->medias->Audio->Apc GrooveBox->1_Hit Hat
->2_Kick
->3-Snare
->4-Others
Each folders for a sampler.
In each of the folders i put an "white_empty_sound".
I create in the "Sub patch seqline" a sampler_rec and i link everything who is linked to the sampler.
I creat the In and out links.
The sound go through the Groove it works.
Now when i apply polyphonie in my sub patch i loose all the midi separated connections between the samplers and the apc.
I can only control all the pitch at the same time with only one button.
I loose the independance of the samplers. Everything begin commun...
I don't know how to fixe it or how to apply the polyphonie and keep the basic configuration...
Statistics: Posted by thomaschamotte — 10 Sep 2017, 22:27
2017-09-10T17:36:56+02:00 2017-09-10T17:36:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37734#p37734 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> Awesome man !
Statistics: Posted by thomaschamotte — 10 Sep 2017, 17:36
2017-09-10T17:35:24+02:00 2017-09-10T17:35:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37733#p37733 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> in Usine /browser/addon , use the update from internet button, then in the groove makers folder , you'll see Apc GrooveBox Xl
Statistics: Posted by nay-seven — 10 Sep 2017, 17:35
2017-09-10T17:28:27+02:00 2017-09-10T17:28:27+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37732#p37732 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> i think the last version is this one : matrix groove by APC proto 9
But we can't see the gain volume one the Right side of the matrix so it make me ask myself if it's really the last one.
I'm trying right to change all your sampler as sampler record, because i would like to work with your Groove patch and record in it at the same time.
I like your patch !
Statistics: Posted by thomaschamotte — 10 Sep 2017, 17:28
2017-09-10T17:23:46+02:00 2017-09-10T17:23:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37731#p37731 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> Statistics: Posted by nay-seven — 10 Sep 2017, 17:23
2017-09-10T16:49:07+02:00 2017-09-10T16:49:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37730#p37730 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> i don't find your link with the last version of your patch as the one you use in your video or the one you have puted in uploader ".png".
Did you puted it online ?
Statistics: Posted by thomaschamotte — 10 Sep 2017, 16:49
2017-09-03T15:50:24+02:00 2017-09-03T15:50:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37715#p37715 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
Discussion here :http://www.sensomusic.org/forums/viewtopic.php?pid=37714#p37714
video overview :https://vimeo.com/232225617
Thanks again for ideas and debugging.
Statistics: Posted by nay-seven — 03 Sep 2017, 15:50
2017-09-01T12:00:19+02:00 2017-09-01T12:00:19+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37708#p37708 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> waiting for this, open the options panel, move the fader to find the knob corresponding, in its settings panel/midi tab, set the midi learn to inverse
about the first led, i mean the first round button above the faders, you must have 4 buttons in red
About order, we can discuss, and you can change this, with the midi learns, but for me left to right correspond to down to up ?
Statistics: Posted by nay-seven — 01 Sep 2017, 12:00
2017-09-01T03:13:00+02:00 2017-09-01T03:13:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37705#p37705 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> The fader who control the gain of the sequencer nbr 4 (seconde extrem left of the APC) is going revers.
When i level up the gain go down, when i level down the gain goes up.
Statistics: Posted by thomaschamotte — 01 Sep 2017, 03:13
2017-09-01T03:08:28+02:00 2017-09-01T03:08:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37704#p37704 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
Finally i like your solution for the volume of the sequencers without the shift button... i have to find an other hardware to control the others fader of my plugin.
Statistics: Posted by thomaschamotte — 01 Sep 2017, 03:08
2017-08-31T23:11:31+02:00 2017-08-31T23:11:31+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37703#p37703 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> It's gonna be one of my stage instrument !
The aesthetic of your interface is very cool ! Very nice !
And the settings are now really confortable.
Big job.
Questions and remarks
- Do you think the sens of the faders who control the Gain and the Pitch are not revers ?
Because i have tried the patch in a real situation and all the time i miss that the first left fader is for the sequence number 4.
The sens of occidental reading is left to right, 0 to 1.
- The two last row are for the presets. I will use only 8 preset max and use the last row to control buttons i have created for the Groove Physics.
- the First led of each sequence stay lighted doesn't work.
- In my schematic you finally have only one free last button on the right below the Select Button. Am i rong ?
- I continu to think it could be awesome to use the Gain and Pitch Faders with an 2nd Shift Button to be free to use the faders as we want.
- The Main Gain is a good idea !
Statistics: Posted by thomaschamotte — 31 Aug 2017, 23:11
2017-08-31T22:27:25+02:00 2017-08-31T22:27:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37702#p37702 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
ok, glad you like it and all works well
about the select button : press it and keep it pressed, now press one of the pad of the visualization sequence to set the sequence length.
About your suggestions, i will think about it, but understand i can't add all your personal needs, my purpose is now to create an add-on for everyone. ( what's about an other controller like a nanokontrol 2 or a xtouch mini to replace ?)
here the new features :
- New interface / colors
- Shift+the main fader on the right will set the main gain
- the row below the visualization sequence are now 8 buses (binds) you can use to start/stop external fx's
- first leds of each sequence stay lighted for a better visualization
- the 2 last rows are presets choice
Download
Ok, i try it right now.
I know you can't add all my personal needs. But it is not just for me... it's for avery body. I think it is more confortable to have a second shift button who can let free the 8 first fader.
I try it.
Statistics: Posted by thomaschamotte — 31 Aug 2017, 22:27
2017-08-31T22:24:40+02:00 2017-08-31T22:24:40+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37701#p37701 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> about the select button : press it and keep it pressed, now press one of the pad of the visualization sequence to set the sequence length.
Download
Statistics: Posted by nay-seven — 31 Aug 2017, 22:24
2017-08-31T21:33:46+02:00 2017-08-31T21:33:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37700#p37700 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> I have tested your patch.
I'm very impressive ! It works very well but there is somethings i don't gat it.
First i have made a picture to visualize what we are talking about.
What i don't gat it :
- I don't know how to use the Select round button...
Idea
I need something but i don't know if it is possible to do it and if it is, i don't know how to do it.
I think it could be more confortable if a second Shift Button is created.
And in this way the second shift button could controlled the Pitch and the Gain of each sequence.
Because in my workspace i already need all the faders.
If Pitch and Gain of sequences are controlled by faders only when "Shift 2" is pressed it is free to use the faders how we want for a Midi Control situation of our personal workspace.
What are you thinking about it ?
I have made a schematic.
Statistics: Posted by thomaschamotte — 31 Aug 2017, 21:33
2017-08-31T09:25:21+02:00 2017-08-31T09:25:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37695#p37695 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
Yes, i've made some progress on this, can be an adddon soon,
What i have now:
-last pressed note can be set a velocity value with the main fader on the right, there 's a color feeedback ( 3 colors but more velocities range)
-others faders ( 2 by track) control gain and pitch ( xy pad)
- if shift pressed, the first fader control the start position of the sampler
- low round button control previous and next samples for each samplers
- up rond right button mute each track,
- select button let you control length of the sequence
- stop all clips button, reset the matrix
- button above random the sequence
todo: presets with the low row
requirement: set your apc MIDI device out to motorized
Can you check all this points and tell me if all works for you ?
Download
Of curse, it's early 3h24 in the morning for me right now. I sleep a wild and i try it !
Statistics: Posted by thomaschamotte — 31 Aug 2017, 09:25
2017-08-31T09:22:20+02:00 2017-08-31T09:22:20+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37694#p37694 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
What i have now:
- if shift pressed, the first fader control the start position of the sampler ( soft take over mode)
Download
Statistics: Posted by nay-seven — 31 Aug 2017, 09:22
2017-08-31T01:31:52+02:00 2017-08-31T01:31:52+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37691#p37691 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
That might be interesting to have "the last button pressed" of your patch to control with one of the potentiometers of the APC, the velocity of the any 32 buttons used by the matrix.
But, when you control with the mouse the velocity of the notes directly in Usine on the "Groove matrix" and after you want to shut down or open up a note with the APC Mini, the velocity you have choosen with your mouse is not maintained. The value is on the top.
So... the last button pressed could be the solution.
After,
the Shift Button of arGrid might be a powerful solution to integrate the APC Mini and control the gain and the pitch of each sequencer with 4 potentiometers. 4 for the gain in the unshift potition and the same 4 for the pitch in the Shift position.
Just ideas.
Statistics: Posted by thomaschamotte — 31 Aug 2017, 01:31
2017-08-29T22:14:55+02:00 2017-08-29T22:14:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37685#p37685 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> akai has a strange implementation:
if you want light a pad, you need to send a note On with velocity 01 for green color, to light off this pad, you need to send...a note off ? no will be too simple, but a new note On with velocity of 0
Then color order are also strange, 01 will give you a green pad, 02 a green blink pad ! 03 a red pad , 04 a blink red and so...
and the challenge is to modify the array of the matrix and the gain of the sampler...
Statistics: Posted by nay-seven — 29 Aug 2017, 22:14
2017-08-29T21:41:42+02:00 2017-08-29T21:41:42+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37683#p37683 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> Do you think it can works on your neaw patch ?
Statistics: Posted by thomaschamotte — 29 Aug 2017, 21:41
2017-08-29T19:48:21+02:00 2017-08-29T19:48:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37681#p37681 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> i don't have assign the shift button to anything in this patch ( around 3 hours on modifications yet today ;-) )
Statistics: Posted by nay-seven — 29 Aug 2017, 19:48
2017-08-29T19:35:53+02:00 2017-08-29T19:35:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37680#p37680 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> But the colors works.
I don't understand wet how works the shift button.
Statistics: Posted by thomaschamotte — 29 Aug 2017, 19:35
2017-08-29T19:20:55+02:00 2017-08-29T19:20:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37679#p37679 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]> color feedback on the pads? ( steps in red, notes in amber)
reset all pads?
sequence length ?
on my side i use the 8 faders to control the 4 xy , fun
Statistics: Posted by nay-seven — 29 Aug 2017, 19:20
2017-08-29T19:13:02+02:00 2017-08-29T19:13:02+02:00 https://brainmodular.org/forums/viewtopic.php?t=5848&p=37678#p37678 <![CDATA[Akai APC Mini and Sequencer (Exemple with Patch Groove Matrix)]]>
Thank for for updating the conversation.
I tried your patch.
You true there is only three colors with the APC Mini. But it is a reason of not being able to control the gain on each button ?
Tomorrow i will check it.
Statistics: Posted by thomaschamotte — 29 Aug 2017, 19:13
This is the way :
->2_Kick
->3-Snare
->4-Others
I like your patch !
Big job.
Download
I try it.
Download
Idea
What i have now:
Download
What i have now:
Download
After,
Just ideas.
reset all pads?
sequence length ?
I tried your patch.
