Statistics: Posted by noise2sine — 19 Aug 2017, 22:49
]]>2017-08-19T15:58:55+01:002017-08-19T15:58:55+01:00https://brainmodular.org/forums/viewtopic.php?t=5844&p=37601#p37601use the text outlet here the patch: Download
Statistics: Posted by nay-seven — 19 Aug 2017, 16:58
]]>2017-08-19T15:10:42+01:002017-08-19T15:10:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5844&p=37600#p37600 Sorry but i didn't manage to do what you said : i have a list box and the master sync module. The comma text outlet of the list box is conected to the bar list of the synch module . But i didn't find a way to create the list
What am i missing ?
thank you
Statistics: Posted by noise2sine — 19 Aug 2017, 16:10
]]>2017-08-19T12:37:25+01:002017-08-19T12:37:25+01:00https://brainmodular.org/forums/viewtopic.php?t=5844&p=37598#p37598Statistics: Posted by noise2sine — 19 Aug 2017, 13:37
2017-08-19T09:29:37+01:002017-08-19T09:29:37+01:00https://brainmodular.org/forums/viewtopic.php?t=5844&p=37595#p37595 list module and a master synchro module - link the comma text outlet of the list module to the list of bars inlet of the master synchro - create your list of bars in the list module, add presets to this patch
Note you can also create a list of bars directly in the settings panel of the master synchro ( main interface)
Statistics: Posted by nay-seven — 19 Aug 2017, 10:29
]]>2017-08-19T08:20:49+01:002017-08-19T08:20:49+01:00https://brainmodular.org/forums/viewtopic.php?t=5844&p=37594#p37594 In the old days i was using the conductor ( USINE V5) in order to change the time signature.The preset in the conductor allowed me to recall settings and sample and time signature.
for example preset 1 : is 4/4 preset 2 : is 7/16
How can i reproduce this in Hollyhock ?
thank you
Statistics: Posted by noise2sine — 19 Aug 2017, 09:20
What am i missing ?
thank you
]]>2017-08-19T09:29:37+01:002017-08-19T09:29:37+01:00https://brainmodular.org/forums/viewtopic.php?t=5844&p=37595#p37595 list module and a master synchro module - link the comma text outlet of the list module to the list of bars inlet of the master synchro - create your list of bars in the list module, add presets to this patch
thank you
