ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2022-01-14T11:27:29+02:00https://brainmodular.org/forums/app.php/feed/topic/58172022-01-14T11:27:29+02:002022-01-14T11:27:29+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=43885#p43885Then in the folder /Config/ or /contents/Config/ in newest versions
]]>2022-01-12T23:47:40+02:002022-01-12T23:47:40+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=43882#p43882can you help me remember where is the CONFIG folder located on a typical installation on Mac? thanks
Statistics: Posted by unguitar — 12 Jan 2022, 22:47
]]>2020-04-13T00:37:27+02:002020-04-13T00:37:27+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=42400#p42400Statistics: Posted by x.iso — 13 Apr 2020, 00:37
When I update HH to a new version I copy the entire config folder to the new directory. This contains all settings, devices and any user modules that I have downloaded.
Hi, is this still valid when you move from HH3 to HH4? thanks
Statistics: Posted by unguitar — 12 Apr 2020, 16:12
this is it! thank you a lot this is exactly what I was meaning when I began this thread
Statistics: Posted by unguitar — 17 Sep 2017, 09:47
]]>2017-09-14T18:54:55+02:002017-09-14T18:54:55+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37757#p37757import old settings button in the setup/global tab
Statistics: Posted by nay-seven — 14 Sep 2017, 18:54
]]>2017-09-14T18:14:28+02:002017-09-14T18:14:28+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37756#p37756Statistics: Posted by gurulogic — 14 Sep 2017, 18:14
]]>2017-09-14T13:47:08+02:002017-09-14T13:47:08+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37755#p37755
When you save your workspace, you save everything excepted two things : - the devices (audio in/out, midi in/out, video in/out ...) - the general configurations
So, how do I save these settings?
Statistics: Posted by unguitar — 14 Sep 2017, 13:47
]]>2017-09-14T11:05:18+02:002017-09-14T11:05:18+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37753#p37753 When you save your workspace, you save everything excepted two things : - the devices (audio in/out, midi in/out, video in/out ...) - the general configurations
For backup, you can choose "export workspace", you will make a copy of your project, and have the possibility to add audio files. Then you can save your devices and recall them later with the workspace.
The general configurations change rarely. So, no need to save them with the workspace, and it could be very dangerous in live situation.
Statistics: Posted by SylvainT — 14 Sep 2017, 11:05
]]>2017-09-13T22:13:07+02:002017-09-13T22:13:07+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37750#p37750so it means all the information regarding setup, plugins and so on are stored in the preset itself? Can I completely delete the folder containing the older version and keep just the latest one?
[ edit ] it looks like audio settings are not saved in preset. Audio card and general configuration have to be redone. however, I'm still missing something here. Everything looks like it's fine, I can see audio input in the top meter but it there's no audio is coming in from the channel where it's supposed to. The same workspace runs just fine in the previous build.
Statistics: Posted by unguitar — 13 Sep 2017, 22:13
]]>2017-07-31T10:29:56+02:002017-07-31T10:29:56+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37467#p37467Just drag and drop to open, or you will see the workspaces on the startup Recents.
Statistics: Posted by sephult — 31 Jul 2017, 10:29
]]>2017-07-30T22:06:37+02:002017-07-30T22:06:37+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=37465#p37465what do I have to save to be able to backup my workspace and where do I find those file(s)? thanks
Statistics: Posted by unguitar — 30 Jul 2017, 22:06
]]>BrainModularBrainModular Users Forum2022-01-14T11:27:29+02:00https://brainmodular.org/forums/app.php/feed/topic/58172022-01-14T11:27:29+02:002022-01-14T11:27:29+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=43885#p43885Then in the folder /Config/ or /contents/Config/ in newest versions
]]>2020-04-12T16:12:54+02:002020-04-12T16:12:54+02:00https://brainmodular.org/forums/viewtopic.php?t=5817&p=42394#p42394
