ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-09-20T11:50:14+01:00 https://brainmodular.org/forums/app.php/feed/topic/5809 2017-09-20T11:50:14+01:00 2017-09-20T11:50:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37803#p37803 <![CDATA[Multiple Global Setups]]> Unfortunately it's an hard job safely.
in HH4 ?
Statistics: Posted by senso — 20 Sep 2017, 12:50
2017-07-24T08:29:02+01:00 2017-07-24T08:29:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37446#p37446 <![CDATA[Multiple Global Setups]]> Statistics: Posted by drakh — 24 Jul 2017, 09:29
2017-07-22T14:39:15+01:00 2017-07-22T14:39:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37425#p37425 <![CDATA[Multiple Global Setups]]>
So if the batch file is terminated early, the current config folder you are using (if anything changes) will still remain in the "config" folder.
Because the batch file has been terminated....this "config" will not be re-copied back on-top of the specific xxx_config folder you selected.
When you startup again the next run, this "config" folder is backed up in "config_backup", this way if you accidentally startup again you have one more chance to capture and save as a fail-safe.
This batch file that runs in the background basically is a loop that checks the processes to make sure usine.exe is still running. Once it disappears it throws an error level flag and exits the loop...then triggers the script to copy the "config" folder back over the "xxx_config" folder selected.
So I did put some fail-safe in there for everyone :)
-s
Statistics: Posted by sephult — 22 Jul 2017, 15:39
2017-07-22T04:46:39+01:00 2017-07-22T04:46:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37421#p37421 <![CDATA[Multiple Global Setups]]> Statistics: Posted by gurulogic — 22 Jul 2017, 05:46
2017-07-22T03:56:44+01:00 2017-07-22T03:56:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37420#p37420 <![CDATA[Multiple Global Setups]]> Just a simple batch file...but sometimes simple is good.
I just threw together this morning...went through it quite a bit, but haven't had more than a few hours today using.
-s
Statistics: Posted by sephult — 22 Jul 2017, 04:56
2017-07-22T00:38:11+01:00 2017-07-22T00:38:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37419#p37419 <![CDATA[Multiple Global Setups]]> Statistics: Posted by damstraversaz — 22 Jul 2017, 01:38
2017-07-21T17:27:48+01:00 2017-07-21T17:27:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37418#p37418 <![CDATA[Multiple Global Setups]]>
So in the meantime if you have windows I made a Configuration Manager that handles three different configurations: Performance/Studio/Design
This creates the folders, does the directory/file structure moving etc.
The batch file remains open and automatically saves/backup of the proper configuration.
Current configurations (config folder) are always backed up beforehand.
Hope this is a temporary solution that helps some people, thought it would be fun to throw together.
-As always, back up your current setup before using.
-Place in your current working Usine directory.
-Just change the extension of the .txt to .bat and run.
USINE MULTIPLE CONFIGURATION MANAGER
Statistics: Posted by sephult — 21 Jul 2017, 18:27
2017-07-21T10:28:42+01:00 2017-07-21T10:28:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37415#p37415 <![CDATA[Multiple Global Setups]]> Statistics: Posted by cmodica — 21 Jul 2017, 11:28
2017-07-20T22:07:04+01:00 2017-07-20T22:07:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37412#p37412 <![CDATA[Multiple Global Setups]]> Statistics: Posted by damstraversaz — 20 Jul 2017, 23:07
2017-07-18T21:29:03+01:00 2017-07-18T21:29:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37390#p37390 <![CDATA[Multiple Global Setups]]> I would have one setup for the laptop plugged into audio interface, and another setup for laptop on its own (asio4all and laptop speakers / headphones).
Statistics: Posted by sm_jamieson — 18 Jul 2017, 22:29
2017-07-18T20:47:33+01:00 2017-07-18T20:47:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=5809&p=37389#p37389 <![CDATA[Multiple Global Setups]]>
It's not a matter of great urgency for me, but it seems like it would be convenient to be able to have several global usage profiles that could be either activated at program launch and/or perhaps via module.
Statistics: Posted by gurulogic — 18 Jul 2017, 21:47
in HH4 ?
-s
-s
