ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-10-21T10:48:40+01:00 https://brainmodular.org/forums/app.php/feed/topic/5789 2017-10-21T10:48:40+01:00 2017-10-21T10:48:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=38087#p38087 <![CDATA[Do Your Own Wavetable V3]]>
http://www.sensomusic.com/forums/upload ... YOWTV3.zip
if you are keen to beta test the whole module library I'll be able to give you links soon
olilab101[dkjfhdkfh]gmail.com
Statistics: Posted by oli_lab — 21 Oct 2017, 11:48
2017-10-21T10:00:06+01:00 2017-10-21T10:00:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=38086#p38086 <![CDATA[Do Your Own Wavetable V3]]>
Do you have OSX version?
Regards
Statistics: Posted by SylvainT — 21 Oct 2017, 11:00
2017-08-09T01:08:24+01:00 2017-08-09T01:08:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37517#p37517 <![CDATA[Do Your Own Wavetable V3]]>
for the chunk i don't recall if you are obliged to implement,
you are right ! I checked the SDK exemples and many of them don't implement the chunk system.
I removed all the variable declaration from the onprocess() to the .h
still I have trouble when changing presetr, but not all the time... :/
Statistics: Posted by oli_lab — 09 Aug 2017, 02:08
2017-08-07T16:15:32+01:00 2017-08-07T16:15:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37493#p37493 <![CDATA[Do Your Own Wavetable V3]]>
for the chunk i don't recall if you are obliged to implement, but i usually do as its nice not only for presets, but to store/recall variables on closing/reopening the patch too, it then store recall a 'chunk' too as i understand via those procedures. Maybe if you don't implement usine doesn't get right a valid size and it leads to memory problems tho it shouldn't i suppose, not sure if related to your issue.
Statistics: Posted by 23fx23 — 07 Aug 2017, 17:15
2017-08-05T21:08:32+01:00 2017-08-05T21:08:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37487#p37487 <![CDATA[Do Your Own Wavetable V3]]> Statistics: Posted by oli_lab — 05 Aug 2017, 22:08
2017-08-03T13:49:59+01:00 2017-08-03T13:49:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37478#p37478 <![CDATA[Do Your Own Wavetable V3]]> should I implement the chunk system even if I don't save anything in preset ????
or is temp variable declaration in the process loop an issue ????
kind of make some NAN (not a number) on the output when preset are changed.
this is far behong my comprehension !
still working on it tho as I want to make the wave table circular...
Statistics: Posted by oli_lab — 03 Aug 2017, 14:49
2017-07-06T18:33:29+01:00 2017-07-06T18:33:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37313#p37313 <![CDATA[Do Your Own Wavetable V3]]>
File uploaded: http://www.sensomusic.com/forums/upload ... OWT_V3.zip
Statistics: Posted by oli_lab — 06 Jul 2017, 19:33
2017-07-06T15:12:30+01:00 2017-07-06T15:12:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37312#p37312 <![CDATA[Do Your Own Wavetable V3]]> Statistics: Posted by oli_lab — 06 Jul 2017, 16:12
2017-07-06T14:38:50+01:00 2017-07-06T14:38:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37311#p37311 <![CDATA[Do Your Own Wavetable V3]]>
Statistics: Posted by 23fx23 — 06 Jul 2017, 15:38
2017-07-05T23:04:50+01:00 2017-07-05T23:04:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37303#p37303 <![CDATA[Do Your Own Wavetable V3]]>
Love your wavetables and super-oli addon packs though, awesome to hear!
-s
Statistics: Posted by sephult — 06 Jul 2017, 00:04
2017-07-05T17:22:53+01:00 2017-07-05T17:22:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=5789&p=37299#p37299 <![CDATA[Do Your Own Wavetable V3]]>
the module can record 2 minutes of audio, make it in a large wavetable that can be played on up to 64 separate outputs.
+ few options as the "constant pitch", morphing between current wave and next one, minimal snippet size...
pre-release will soon be in the addons list with all the up to date modules from my lab !
Enjoy !
P.S. there was a small bug and now it is fix (so I think)
Statistics: Posted by oli_lab — 05 Jul 2017, 18:22
Regards
-s
Enjoy !
