ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2019-06-09T23:38:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/5760 2019-06-09T23:38:16+01:00 2019-06-09T23:38:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=41413#p41413 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by sguyader — 10 Jun 2019, 00:38
2019-06-08T17:09:34+01:00 2019-06-08T17:09:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=41410#p41410 <![CDATA[Anyone else not able to load VST plugins with HH3?]]>
I'm having some troubles using many plugins. I'm on a win 10 pc, brand new laptop. Usine doesn't seem to be able to "see" many plugins i downloaded (all 64bit) when scanning.
Check if you're using 64bit version of Usine and locations of course. Also, sometimes after migrating settings from one installation to newer, you might need to re-enter locations for plugins and rescan then.
Statistics: Posted by x.iso — 08 Jun 2019, 18:09
2019-06-08T16:57:16+01:00 2019-06-08T16:57:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=41409#p41409 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by A_L — 08 Jun 2019, 17:57
2017-07-08T10:39:53+01:00 2017-07-08T10:39:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37326#p37326 <![CDATA[Anyone else not able to load VST plugins with HH3?]]>
works very well with
HOFA SYSTEM ONE
modularity in a modular environment
great fun & sound
w.
Statistics: Posted by planktone — 08 Jul 2017, 11:39
2017-07-02T12:26:07+01:00 2017-07-02T12:26:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37249#p37249 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by Blaakk — 02 Jul 2017, 13:26
2017-06-30T16:41:02+01:00 2017-06-30T16:41:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37208#p37208 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Didn't happen with HH2. VSTs are smooth sailing though.
Statistics: Posted by lytz1 — 30 Jun 2017, 17:41
2017-06-30T06:15:35+01:00 2017-06-30T06:15:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37189#p37189 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by dmitriyc — 30 Jun 2017, 07:15
2017-06-28T09:22:44+01:00 2017-06-28T09:22:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37158#p37158 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> sorry for the headache but there so many différent plug-ins programmation, Usine is sometimes lost !
Statistics: Posted by nay-seven — 28 Jun 2017, 10:22
2017-06-28T06:51:53+01:00 2017-06-28T06:51:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37156#p37156 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> I deleted a bunch of unused components and vsts and that seems to have done the trick! awesome!
Statistics: Posted by dmitriyc — 28 Jun 2017, 07:51
2017-06-28T06:28:26+01:00 2017-06-28T06:28:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37155#p37155 <![CDATA[Anyone else not able to load VST plugins with HH3?]]>
UPDATE:
so....tried reinstalling HH3, tried to point the vst folders to an empty folder on HH2 just for giggles. Apparently HH3 doesn't like Massive. It gets stuck at 17% specifically on the Massive Audio Unit. @nay-seven: I tried your solution, but it seems to just want to happen over and over. A thing to note: even though I pointed HH2 plugin folders away from what they previously were, HH3 new installation came with those folders already pointed to the old ones, not an empty folder. Any ideas?
Statistics: Posted by dmitriyc — 28 Jun 2017, 07:28
2017-06-28T05:43:17+01:00 2017-06-28T05:43:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37154#p37154 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by dmitriyc — 28 Jun 2017, 06:43
2017-06-27T22:50:58+01:00 2017-06-27T22:50:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37146#p37146 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by joffo78 — 27 Jun 2017, 23:50
2017-06-27T17:35:55+01:00 2017-06-27T17:35:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37144#p37144 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by sephult — 27 Jun 2017, 18:35
2017-06-27T16:57:28+01:00 2017-06-27T16:57:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37139#p37139 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> you can find some files to study :
Usine.app/Config/Plug-InsCorruptedPlugins.init and ErrorPlugins.init
These are text file, so you can read them with textEdit, then you can try to deplace some of them and retry the scan
Statistics: Posted by nay-seven — 27 Jun 2017, 17:57
2017-06-27T16:18:03+01:00 2017-06-27T16:18:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=5760&p=37137#p37137 <![CDATA[Anyone else not able to load VST plugins with HH3?]]> Statistics: Posted by dmitriyc — 27 Jun 2017, 17:18
HOFA SYSTEM ONE
great fun & sound
w.
UPDATE:
