ArrayArray BrainModular BrainModular Users Forum 2007-09-20T19:33:54+01:00 https://brainmodular.org/forums/app.php/feed/topic/572 2007-09-20T19:33:54+01:00 2007-09-20T19:33:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=572&p=2801#p2801 <![CDATA[some suggestions]]> thanks for feedbacks.
yes it's very clear.
When you add some input/output in a subpatch (in arbitrary order).
The connectors allready plugged of the subpatch box are not updated and become false.
I know, but it's hard to know what have to be corrected. For example, if your control is also connected to another and so on?
When we "copie/paste" a multi-selection, the modules position isn't copied and reformated. which is bad with complex selections.
Each control is "shifted" a little. I'll correct that point
I want to be able to add the "content" of a patch in the browser in the actual patch.
For now, we have just the "load"(drag/drop) and "insert"(ctrl + drag/drop) fonctions, and i want an "insert content"(alt or shift + drag/drop).
Maybe a 'select all' in the edit menu can, for the beginning, do a good job? I'll think about that.
A drag multi-selection box would be good in addition of the existing click and ctrl-multi-click selection mode in the patch design window.
Yes I'll try to find something!
Statistics: Posted by senso — 20 Sep 2007, 20:33
2007-09-20T18:18:10+01:00 2007-09-20T18:18:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=572&p=2793#p2793 <![CDATA[some suggestions]]>
I'm using usine for some times now and i have some suggestions for you'r "todo list" ;-)
[correction]
For now, you must redo all the connexions, which is bad.
[feature request]
Hope it's clear, ask me if needed.
anyway, you'r making hard good job these days, keep it up :-)
Statistics: Posted by martignasse — 20 Sep 2007, 19:18
[correction]
[feature request]
