ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-03-25T14:54:37+02:00 https://brainmodular.org/forums/app.php/feed/topic/5700 2017-03-25T14:54:37+02:00 2017-03-25T14:54:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36897#p36897 <![CDATA[Need help with sending my first MIDI message to external gear]]>
Also there was something up with my output setup - I never did work out what it was but rebuilding from scratch referencing nay-seven's basic workspace fixed it.
Statistics: Posted by gron — 25 Mar 2017, 13:54
2017-03-19T19:27:17+02:00 2017-03-19T19:27:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36872#p36872 <![CDATA[Need help with sending my first MIDI message to external gear]]> out is correctly activated in the setup /midi tab?
you have drag it from the device panel on your rack output ?
audio engine of Usine is ON ?
here a basic workspace sending a note on and a CC, of course you'll have an error about the midi out device i've used but maybe can help
download
Statistics: Posted by nay-seven — 19 Mar 2017, 18:27
2017-03-19T18:45:53+02:00 2017-03-19T18:45:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36871#p36871 <![CDATA[Need help with sending my first MIDI message to external gear]]>
I can get messages from everything in my trace window but can't seem to send out.
To troubleshoot and shift approach I'm now trying to get a signal to MIDI-OX, no luck there either. I set up ports to and from MIDI-OX and set them up to send and receive in Usine. I must be missing something obvious.
I'm on a brand new well equipped Win10 i7 PC solely for making music with almost nothing on it. Ableton, Usine, MIDI-OX and a handful of plugins.
I'm running out of hair to tear out! :/
Can someone please offer me a next step?
Statistics: Posted by gron — 19 Mar 2017, 17:45
2017-03-18T17:04:37+02:00 2017-03-18T17:04:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36866#p36866 <![CDATA[Need help with sending my first MIDI message to external gear]]> I've set up exactly as suggested - Totally missed dragging the midi device to my output so that's pretty serious!
Surprisingly I'm still not seeing or getting any signal through for some reason.
I even replicated the exercises for simple note on generators in the patching tutorial pdf (page 23) and I'm having the same issues.
What's the best way to set up trace on this in a way that can tell me what's getting through or not?
Edit: I worked out I can click on the wires and get trace values... everything seems ok until the output ... I'm unsure how to trace that. I see nothing in the trace window and nothing popping up in MIDI-OX either (thought I better check in case there's a hardware or cable issue)
If it's in the manuals or these forums I'm clearly searching the wrong stuff.
Am at a loss :(
Statistics: Posted by gron — 18 Mar 2017, 16:04
2017-03-17T19:02:38+02:00 2017-03-17T19:02:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36864#p36864 <![CDATA[Need help with sending my first MIDI message to external gear]]> Statistics: Posted by joffo78 — 17 Mar 2017, 18:02
2017-03-17T15:09:08+02:00 2017-03-17T15:09:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36863#p36863 <![CDATA[Need help with sending my first MIDI message to external gear]]> Statistics: Posted by 23fx23 — 17 Mar 2017, 14:09
2017-03-17T13:53:09+02:00 2017-03-17T13:53:09+02:00 https://brainmodular.org/forums/viewtopic.php?t=5700&p=36862#p36862 <![CDATA[Need help with sending my first MIDI message to external gear]]> Am pretty sure I'm missing something obvious.
I'm trying to start with the basics...
For now my (simple?) goal is to create a button that sends a MIDI control change of value 31 to external gear
(a lehle 3@1 in omnichannel mode connected via my Roland MX-1)
I've got my midi input and outputs setup and I'm seeing my external gear in the trace box so I'm confident that is working.
Right now I'm looking at this ...
Create Midi settings are this:
I notice that when I select "Control Change" it changes it to a "Note On"... this can't be good
Maybe need to set up my midi output in the rack not just the patch? If this is the case I'm not sure how.
I tried to add a trace to the CreateMidi/out but either no signal gets through when I click the button or I'm just doing it wrong.:/
Statistics: Posted by gron — 17 Mar 2017, 12:53
download
Am at a loss :(
