ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2018-02-19T08:19:11+01:00https://brainmodular.org/forums/app.php/feed/topic/56622018-02-19T08:19:11+01:002018-02-19T08:19:11+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39429#p39429Statistics: Posted by oli_lab — 19 Feb 2018, 08:19
2018-02-19T00:53:37+01:002018-02-19T00:53:37+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39428#p39428But for MPE, if notes really are just sent to different channels, then it's quite easy to adapt any VST for it with polyphonic patch. I'm already doing that for different purposes, but might try implement MPE with touch keyboard patch (no pressure sensitivity though, just up-down for velocity/aftertouch) using same principle (distributing notes to different channels).
]]>2018-02-16T14:52:51+01:002018-02-16T14:52:51+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39415#p39415Statistics: Posted by 23fx23 — 16 Feb 2018, 14:52
]]>2018-02-16T14:41:05+01:002018-02-16T14:41:05+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39413#p39413https://sensel.com/
looks even cooler !? can be totally customized. I'll dig into that : I want to build a stand alone OSC controller with it !
Statistics: Posted by oli_lab — 16 Feb 2018, 14:41
]]>2018-02-16T14:04:27+01:002018-02-16T14:04:27+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39412#p39412but their scripting engine app 'dashboard' is very fast and nice and in any case it s possible to reroute messages the way we want so i don't think that would be a problem to patch something out of the box or via slight dashboard script editing if that would fit more for usine
]]>2018-02-15T01:28:50+01:002018-02-15T01:28:50+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39405#p39405 shouldn't be a problem to make a 15 voice polyphonic subpatch that parse ch2-16 to one of 15 instances of a vst instrument or else and send the ch1 to each voices ?
did any one using the Roli keyboard ? I'm interrested of getting the block version and give it a go with custom samplers...
I could eventually build a sdk user module(s) to be use with MPE interfaces !
sounds cool ?
Statistics: Posted by oli_lab — 15 Feb 2018, 01:28
]]>2017-01-22T15:32:52+01:002017-01-22T15:32:52+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=36652#p36652I'd need to see how that was working. Will have a look at the Max/MSP package tomorrow and see if I can parse the messages.
]]>2017-01-22T10:31:48+01:002017-01-22T10:31:48+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=36644#p36644 "The Lightpad Block sends its 5 dimensions of touch using five standard MPE messages.
Strike sends note-on messages in addition to velocity 0–127. Press sends channel pressure (aftertouch). Glide sends pitch bend. Slide sends CC 74. Lift sends note-off and release velocity 0–127."
so the MIDI filter modules lets you select and create a specific device ?
Statistics: Posted by nay-seven — 22 Jan 2017, 10:31
]]>2017-01-22T02:57:35+01:002017-01-22T02:57:35+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=36643#p36643Are there any modules that will parse the multidimensional midi data? I could not find any by searching.
]]>BrainModularBrainModular Users Forum2018-02-19T08:19:11+01:00https://brainmodular.org/forums/app.php/feed/topic/56622018-02-19T08:19:11+01:002018-02-19T08:19:11+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39429#p39429Statistics: Posted by oli_lab — 19 Feb 2018, 08:19
]]>2018-02-19T00:53:37+01:002018-02-19T00:53:37+01:00https://brainmodular.org/forums/viewtopic.php?t=5662&p=39428#p39428But for MPE, if notes really are just sent to different channels, then it's quite easy to adapt any VST for it with polyphonic patch. I'm already doing that for different purposes, but might try implement MPE with touch keyboard patch (no pressure sensitivity though, just up-down for velocity/aftertouch) using same principle (distributing notes to different channels).
sounds cool ?
