ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-09-19T14:05:18+01:00 https://brainmodular.org/forums/app.php/feed/topic/566 2007-09-19T14:05:18+01:00 2007-09-19T14:05:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2766#p2766 <![CDATA[New version (3.22 beta1) Update]]>
that interface builder is one of the key features if you want to use usine live
k
Statistics: Posted by kara — 19 Sep 2007, 15:05
2007-09-19T13:01:30+01:00 2007-09-19T13:01:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2764#p2764 <![CDATA[New version (3.22 beta1) Update]]> I'm working on that point and the ability to create very personnal interface with skins, etc...
Statistics: Posted by senso — 19 Sep 2007, 14:01
2007-09-19T11:27:18+01:00 2007-09-19T11:27:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2762#p2762 <![CDATA[New version (3.22 beta1) Update]]>
I also wouldn't mind it if the objects kept their sizes when unlocked - with the title bars..
i second that , those title bars are really painful when organize big interface
Statistics: Posted by nay-seven — 19 Sep 2007, 12:27
2007-09-19T08:42:40+01:00 2007-09-19T08:42:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2759#p2759 <![CDATA[New version (3.22 beta1) Update]]>
Edit:
Of course I meant without the titlebars...
Statistics: Posted by bsork — 19 Sep 2007, 09:42
2007-09-19T08:08:57+01:00 2007-09-19T08:08:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2758#p2758 <![CDATA[New version (3.22 beta1) Update]]> Here is my problem :
I build a patch with a number of controls on the interface builder.
Now I save that patch as a sub patch.
When I now load a second copy of that sub patch, the controls are placed on the interface exactly on top of the controls of the first patch. Which means I have to manualy place (slide) all controls of the second sub patch.
Would it be possible to, by default, when you load a sub patch select ALL components of the loaded sub patch so that you can slide them as a GROUP in the interface builder ?
This would be a BIG improvement, saving a lot of time when building interfaces.
k
Statistics: Posted by kara — 19 Sep 2007, 09:08
2007-09-19T06:41:24+01:00 2007-09-19T06:41:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2757#p2757 <![CDATA[New version (3.22 beta1) Update]]> Fixed Now.
next release
Statistics: Posted by senso — 19 Sep 2007, 07:41
2007-09-18T16:37:12+01:00 2007-09-18T16:37:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2756#p2756 <![CDATA[New version (3.22 beta1) Update]]> I Have a big problem with interface builder. I have build an interface for my live set with a lot of objects (more than 100 objects, fader , meters, switches, pictures instruments ....). I have organized all objects in the windows (I have a big window for all objects) and after that (long time to do that...) , sometimes if I modify the size of the window (interface builder) half of my objects have change of place, damned ...
And I cannot to recover the good place. I must to move objects one by one.....
That arrives too (sometimes) when I start usine later, objects are shifted..
I think it is a bug, now I stop and wait.
Franck
Statistics: Posted by franck — 18 Sep 2007, 17:37
2007-09-18T11:46:00+01:00 2007-09-18T11:46:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=566&p=2754#p2754 <![CDATA[New version (3.22 beta1) Update]]> [3.22beata1] 07/09/17
Improvements
-new important changes in the Pianoroll module
+ move/resize notes
+ delete notes with a double click
+ create a new note with a double click on an empty area
+ unlimited undo
-[lock] markers switch in the ruler (disable changes)
fixed bugs
-[Shift+S],[Shift+M] short cuts doesn't work
-some Ohmforce plugs sill not working...
-problems with Open Sound Control/Lan setup, may crashes Usine at the
start up
-double click on wavedisplay, the editor stays in "Move Loop" mode.
-the symbol of volume curve is displayed twice.
Statistics: Posted by senso — 18 Sep 2007, 12:46
k
Edit:
k
next release
Franck
Improvements
+ move/resize notes
+ unlimited undo
fixed bugs
start up
