ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-01-12T02:50:56+01:00 https://brainmodular.org/forums/app.php/feed/topic/5648 2017-01-12T02:50:56+01:00 2017-01-12T02:50:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36605#p36605 <![CDATA[arrays of color?]]>
I'm happy just sending H and S tho. It works well, and I can control L globally to have a brightness control for the whole wkp!
Statistics: Posted by woodslanding — 12 Jan 2017, 02:50
2017-01-11T12:14:20+01:00 2017-01-11T12:14:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36601#p36601 <![CDATA[arrays of color?]]> but so i don't understand, in wich situation did you 'get 0s out' of array?
Statistics: Posted by 23fx23 — 11 Jan 2017, 12:14
2017-01-11T05:15:09+01:00 2017-01-11T05:15:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36599#p36599 <![CDATA[arrays of color?]]>
by waiting could make a polyphonic patch with ie a simple color fader or colors io to quickly generate a 'color array'
but how would you send it anywhere?? Can colors even go through busses safely? I thought all values in usine were just 1 item arrays....
Are the individual values for HS and L also not normal usine flows?
What I did was make 2 different arrays, one for HUES and one for SATURATIONS. Then at the recieving end, I feed the appropriate items from each array to an HSL module. saturation and level controls are set at the destination. So far it has worked.....
Statistics: Posted by woodslanding — 11 Jan 2017, 05:15
2017-01-11T01:03:08+01:00 2017-01-11T01:03:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36598#p36598 <![CDATA[arrays of color?]]> Statistics: Posted by 23fx23 — 11 Jan 2017, 01:03
2017-01-10T22:44:12+01:00 2017-01-10T22:44:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36595#p36595 <![CDATA[arrays of color?]]>
Statistics: Posted by nay-seven — 10 Jan 2017, 22:44
2017-01-10T21:56:18+01:00 2017-01-10T21:56:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36593#p36593 <![CDATA[arrays of color?]]>
so are you saying the color output on the HSLA is a different format than the regular color? Or are you saying to create arrays of H,S,L and A, and reconstruct the color at the other end?
I might try the latter, and see if it works. In my application, using color selectors seams really, really heavy.
Statistics: Posted by woodslanding — 10 Jan 2017, 21:56
2017-01-07T21:42:01+01:00 2017-01-07T21:42:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36581#p36581 <![CDATA[arrays of color?]]> and display 'NAN', so it's not safe imo to manipulate with 'classical' float wires like arrays and all.
should use dedicaced color modules like color selector or color dispatcher.
Statistics: Posted by 23fx23 — 07 Jan 2017, 21:42
2017-01-07T19:42:30+01:00 2017-01-07T19:42:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36578#p36578 <![CDATA[arrays of color?]]> Statistics: Posted by nay-seven — 07 Jan 2017, 19:42
2017-01-07T17:19:10+01:00 2017-01-07T17:19:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=5648&p=36576#p36576 <![CDATA[arrays of color?]]>
What's the proper way to do this?
Statistics: Posted by woodslanding — 07 Jan 2017, 17:19
