ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-01-17T14:57:55+01:00 https://brainmodular.org/forums/app.php/feed/topic/5645 2017-01-17T14:57:55+01:00 2017-01-17T14:57:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36618#p36618 <![CDATA[Edit multiple items]]> I agree with you.
But you have many solutions with sub patch and container to group items and being more efficient in positioning mutli gui objects.
And you can easily change the where option of the sub patch or the container
BTW, it will be good to have the possibility to select several objects to move them and arrange them.
Regards
Statistics: Posted by SylvainT — 17 Jan 2017, 14:57
2017-01-16T18:57:04+01:00 2017-01-16T18:57:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36614#p36614 <![CDATA[Edit multiple items]]> Statistics: Posted by oli_lab — 16 Jan 2017, 18:57
2017-01-16T16:46:33+01:00 2017-01-16T16:46:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36613#p36613 <![CDATA[Edit multiple items]]> Statistics: Posted by hgermain — 16 Jan 2017, 16:46
2017-01-05T19:19:34+01:00 2017-01-05T19:19:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36568#p36568 <![CDATA[Edit multiple items]]> Statistics: Posted by gurulogic — 05 Jan 2017, 19:19
2017-01-05T17:59:52+01:00 2017-01-05T17:59:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36567#p36567 <![CDATA[Edit multiple items]]> Statistics: Posted by gurulogic — 05 Jan 2017, 17:59
2017-01-05T15:22:13+01:00 2017-01-05T15:22:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36566#p36566 <![CDATA[Edit multiple items]]>
I've always thought this would be one of the biggest enhancements for efficient design in HollyHock.
Having the ability to Unlock, select multiple items, and drag them keeping their spacing would be wonderful.
I don't know how many hours I've spent tweaking an interface, just to go change things and have to manually one-by-one arrange them.
I love your idea of parameter filtering based on a selection, that would be a Huge improvement.
-s
Statistics: Posted by sephult — 05 Jan 2017, 15:22
2017-01-05T11:45:09+01:00 2017-01-05T11:45:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=5645&p=36565#p36565 <![CDATA[Edit multiple items]]>
It would be a huge workflow improvement to be able to edit multiple items' parameters. In multi mode, the parameter window would filter to only show those parameters that all the objects have in common. You could switch it on and off, although I might leave it on, since it is often ambiguous which object you are editing anyway, if many are selected.
But it would be so nice to select a dozen gui objects, and change all their 'where' values, or give them the same x position or y position or background color..... select a bunch of busses, and set their scope to 'rack'... etc, etc....
cheers,
-eric
Statistics: Posted by woodslanding — 05 Jan 2017, 11:45
Regards
-s
cheers,
-eric
