ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-12-22T16:47:52+01:00 https://brainmodular.org/forums/app.php/feed/topic/5628 2016-12-22T16:47:52+01:00 2016-12-22T16:47:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=5628&p=36519#p36519 <![CDATA[settings in user defined tabs]]> I'll think about.
Statistics: Posted by senso — 22 Dec 2016, 16:47
2016-12-22T15:31:24+01:00 2016-12-22T15:31:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=5628&p=36516#p36516 <![CDATA[settings in user defined tabs]]>
I already use the 23fx23 workaround.
Perhaps the SDK sdkAddSettingLine routines could include a parameter that indicates whether you want it on a module pin or not - so they do not all appear as pins by default - which could make the module too big.
The issue for me is more arranging settings in a logical manner across the tabs, but this is restricted if you also want the settings as pins. It like a great flexibility that is then half taken away again !
Simon,
Statistics: Posted by sm_jamieson — 22 Dec 2016, 15:31
2016-12-21T17:45:56+01:00 2016-12-21T17:45:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=5628&p=36503#p36503 <![CDATA[settings in user defined tabs]]> the workaround of 23fx is a good option.
I'll think about that.
Statistics: Posted by senso — 21 Dec 2016, 17:45
2016-12-20T03:56:13+01:00 2016-12-20T03:56:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=5628&p=36477#p36477 <![CDATA[settings in user defined tabs]]>
you probably noticed it, but if man use DESIGN_TAB_NAME as tab name they are in design tab or PROPERTIES_TAB_NAME are in info tab and do unfold as input pins, i use this to avoid making io^^
Statistics: Posted by 23fx23 — 20 Dec 2016, 03:56
2016-12-19T18:40:35+01:00 2016-12-19T18:40:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5628&p=36473#p36473 <![CDATA[settings in user defined tabs]]>
Simon.
Statistics: Posted by sm_jamieson — 19 Dec 2016, 18:40
Simon,
Simon.
