ArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-12-21T17:43:22+01:00 https://brainmodular.org/forums/app.php/feed/topic/5627 2016-12-21T17:43:22+01:00 2016-12-21T17:43:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=5627&p=36502#p36502 <![CDATA[point in path - multitouch/array compatible]]> Statistics: Posted by senso — 21 Dec 2016, 17:43
2016-12-16T17:08:08+01:00 2016-12-16T17:08:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=5627&p=36469#p36469 <![CDATA[point in path - multitouch/array compatible]]> Statistics: Posted by 23fx23 — 16 Dec 2016, 17:08
2016-12-16T17:04:41+01:00 2016-12-16T17:04:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=5627&p=36468#p36468 <![CDATA[point in path - multitouch/array compatible]]> Many drawing libraries have this - maybe a user module could use the function from there.
This looks good:
http://geomalgorithms.com/a03-_inclusion.html
Statistics: Posted by sm_jamieson — 16 Dec 2016, 17:04
2016-12-15T14:25:31+01:00 2016-12-15T14:25:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=5627&p=36465#p36465 <![CDATA[point in path - multitouch/array compatible]]>
alternative reflexion, a way to manipulate paths could be nice. for exemple externalize this 'check if in path' via a module, a module would have path input (or XY array) and do this computation,
or for exemple shift path, scale, rotate, swap operations and feed back to path module, wich somehow should be doable just adding path points XY arrays outputs on shape module.
i would pers also love to be able to manipulate in sdk as well. for exemple given a path, easily check if a given XY point is in, . or maybe is there is some workable code to compute this ?
Statistics: Posted by 23fx23 — 15 Dec 2016, 14:25
This looks good:
