ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-09-13T20:16:04+01:00 https://brainmodular.org/forums/app.php/feed/topic/561 2007-09-13T20:16:04+01:00 2007-09-13T20:16:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2721#p2721 <![CDATA[Looking for a simple metronome solution]]> Statistics: Posted by bsork — 13 Sep 2007, 21:16
2007-09-13T15:26:16+01:00 2007-09-13T15:26:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2718#p2718 <![CDATA[Looking for a simple metronome solution]]> honestly I didn't quite know exactly what this patch does but since I usually don't need to do that kind of patching I don't care too much...
Anyways it works like a charm. exactly what I was looking for!
Maybe you should put it in the AddOns section.
Thanx a lot.
Statistics: Posted by nofish — 13 Sep 2007, 16:26
2007-09-13T15:25:07+01:00 2007-09-13T15:25:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2717#p2717 <![CDATA[Looking for a simple metronome solution]]> I've just uploaded a simple metronome
k
Statistics: Posted by kara — 13 Sep 2007, 16:25
2007-09-13T14:53:32+01:00 2007-09-13T14:53:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2716#p2716 <![CDATA[Looking for a simple metronome solution]]>
here's my suggestion. only one sampler needed and separate accent and normal clicks:
so add a sampler, into the file list first add the accent then the normal click sounds. set the sync mode of the sampler to "play button".
add the required audio outputs to the the sampler.
then add a Global Synchro module.
then add a > module in between the two.
then make the following connections:
From bar led (Synchro) to play (Sampler)
From bar pos (Synchro) to A (>)
From Out (>) to file (Sampler)
Set the B port of the > module to 1.
Activate the patch and there you go.
antwan
Statistics: Posted by antwan — 13 Sep 2007, 15:53
2007-09-13T14:52:48+01:00 2007-09-13T14:52:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2715#p2715 <![CDATA[Looking for a simple metronome solution]]> Statistics: Posted by bsork — 13 Sep 2007, 15:52
2007-09-13T14:41:44+01:00 2007-09-13T14:41:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2714#p2714 <![CDATA[Looking for a simple metronome solution]]> Statistics: Posted by nofish — 13 Sep 2007, 15:41
2007-09-13T13:38:24+01:00 2007-09-13T13:38:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2713#p2713 <![CDATA[Looking for a simple metronome solution]]>
Another quick way to add accents, is to connect a synchro module to the pitch inlet via A=B and A*B:
synchro.bar pos -> A=B.A (set B=1) -> A*B.A (set B to eg 12 for an octave up) -> sampler.pitch
I tried something similar with gain, but it didn't work very well...
I too remember that Vincent had created a nifty little metronome patch - maybe it should be in the add-ons?
Statistics: Posted by bsork — 13 Sep 2007, 14:38
2007-09-13T12:49:49+01:00 2007-09-13T12:49:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=561&p=2712#p2712 <![CDATA[Looking for a simple metronome solution]]> What would be the simplest solution?
(There was a metronome patch posted some time ago by Vincent on the forum, but the link has expired... )
Statistics: Posted by nofish — 13 Sep 2007, 13:49
Thanx a lot.
k
antwan
