ArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-11-21T02:46:49+01:00https://brainmodular.org/forums/app.php/feed/topic/55902016-11-21T02:46:49+01:002016-11-21T02:46:49+01:00https://brainmodular.org/forums/viewtopic.php?t=5590&p=36313#p36313Statistics: Posted by Ariajazz — 21 Nov 2016, 02:46
2016-11-19T23:09:38+01:002016-11-19T23:09:38+01:00https://brainmodular.org/forums/viewtopic.php?t=5590&p=36312#p36312Have you tried using a popup window ? You can force its position using module position x/y pins.
Statistics: Posted by La Tenaille — 19 Nov 2016, 23:09
]]>2016-11-19T21:48:37+01:002016-11-19T21:48:37+01:00https://brainmodular.org/forums/viewtopic.php?t=5590&p=36311#p36311Statistics: Posted by Ariajazz — 19 Nov 2016, 21:48
]]>2016-11-15T22:12:55+01:002016-11-15T22:12:55+01:00https://brainmodular.org/forums/viewtopic.php?t=5590&p=36299#p36299 I need to make USINE STAGE v5.8 to store or remember the exact screen position of plugin GUIs when recalled.The idea is to automate some mouse movements and clicks for many plugin's functions that cannot be controlled in any other way (midi, parameters, etc) but by mouse.
Saving the patch and/or workspace don't work. It opens the vst's GUI's kind of randomly, no matter if I reposition the GUIs and save patch and workspace, it does not store the new position. It happens more noticeable with several instances of Amplitube 3. BTW I read an old post from 2009 abut this same issue. Senso responded that the problem was going to be solved in the next release. Mine is 5.80 which I believe it was released on 2011.
Any of you have an idea on how to achieve this?... Thanks a lot guys...
Statistics: Posted by Ariajazz — 15 Nov 2016, 22:12
]]>BrainModularBrainModular Users Forum2016-11-21T02:46:49+01:00https://brainmodular.org/forums/app.php/feed/topic/55902016-11-21T02:46:49+01:002016-11-21T02:46:49+01:00https://brainmodular.org/forums/viewtopic.php?t=5590&p=36313#p36313Statistics: Posted by Ariajazz — 21 Nov 2016, 02:46
]]>2016-11-19T23:09:38+01:002016-11-19T23:09:38+01:00https://brainmodular.org/forums/viewtopic.php?t=5590&p=36312#p36312Have you tried using a popup window ? You can force its position using module position x/y pins.
