ArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-09-20T11:26:23+01:00https://brainmodular.org/forums/app.php/feed/topic/55252016-09-20T11:26:23+01:002016-09-20T11:26:23+01:00https://brainmodular.org/forums/viewtopic.php?t=5525&p=35938#p35938If you need anymore help, let me know and I'll try to respond as best I can.
-s
Statistics: Posted by sephult — 20 Sep 2016, 12:26
]]>2016-09-20T10:47:46+01:002016-09-20T10:47:46+01:00https://brainmodular.org/forums/viewtopic.php?t=5525&p=35935#p35935Statistics: Posted by EspressoPianist — 20 Sep 2016, 11:47
2016-09-19T22:46:44+01:002016-09-19T22:46:44+01:00https://brainmodular.org/forums/viewtopic.php?t=5525&p=35933#p35933Right Click the MIDI Learn Button to bring up the settings panel and you should be able to see what is triggering it.
-s
Statistics: Posted by sephult — 19 Sep 2016, 23:46
]]>2016-09-19T22:24:35+01:002016-09-19T22:24:35+01:00https://brainmodular.org/forums/viewtopic.php?t=5525&p=35932#p35932 I'm trying to set up a stomp box (Tech21 MidiMouse) to run through a list of presets on a MacBook Pro in order. I've set the preset numbers to the stomp box numbers using MidiLearn, and all looks well. However when I try to run through the presets in order the very first preset (and only that one) takes the whole screen into MidiLearn mode. I can use all of the presets perfectly except the very first.
]]>BrainModularBrainModular Users Forum2016-09-20T11:26:23+01:00https://brainmodular.org/forums/app.php/feed/topic/55252016-09-20T11:26:23+01:002016-09-20T11:26:23+01:00https://brainmodular.org/forums/viewtopic.php?t=5525&p=35938#p35938If you need anymore help, let me know and I'll try to respond as best I can.
-s
]]>2016-09-19T22:46:44+01:002016-09-19T22:46:44+01:00https://brainmodular.org/forums/viewtopic.php?t=5525&p=35933#p35933Right Click the MIDI Learn Button to bring up the settings panel and you should be able to see what is triggering it.
-s
