ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2018-02-21T11:21:42+01:00https://brainmodular.org/forums/app.php/feed/topic/55212018-02-21T11:21:42+01:002018-02-21T11:21:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39449#p39449Statistics: Posted by 23fx23 — 21 Feb 2018, 11:21
2018-02-20T22:40:48+01:002018-02-20T22:40:48+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39445#p39445 another suggestion I forgot to share: is it possible to make TF-specific controls of visual elements accessible from inlets? for example I'd like to change size of XYpad dot dynamically depending on other parameters of what I'm controlling.
]]>2018-02-20T14:25:12+01:002018-02-20T14:25:12+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39440#p39440 edit, here a 32bit v1.3 let me know if working https://drive.google.com/open?id=18a-_t ... 5c2uMZVuVB_
]]>2018-02-19T15:55:59+01:002018-02-19T15:55:59+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39434#p39434 but my latest version was in fact 1.3 :/ with a global quite deep core change (only loading the "mode" defined on creation, not all the modes, wich save a lot of ram/cpu/settings in tabs) and lots of few other things done since, like mouse wheel stuff for all items mode, ctl fine/corse , vertical captions (xich allowed to use the global rotation of uine without captions glitches), code cleaning/optimisation bug fixes ect (in fact all wa see upper in this page change log ) so sadly thats a bit complex to dive back and re-mix versions but ill try to re-update, won't be before 3 weeks to ihave to move foreign..
@x.iso i agree about the sizes 'templates' but sadly afaik current sdk doesn't allow resize of module after the popup, its defined before and can't be dynamically altered. there could be a trick with iml but that would imply renaming the module on creation and would mess existing setups that would use iml to acces module datas so not sur i can currently, ill check with olivier if some tricks could be done.
]]>2018-02-19T15:12:17+01:002018-02-19T15:12:17+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39432#p39432If mouse wheel is supported - apologies ! but please tell me where the setting is.
Thanks, Simon.
Statistics: Posted by sm_jamieson — 19 Feb 2018, 15:12
]]>2018-02-19T14:30:19+01:002018-02-19T14:30:19+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39431#p39431- when changing fader orientation from vertical to horizontal in style panel, the grid stays in vertical orientation, which is probably just a bug. - by default UI of Touch Fader control is rectangular and in some modes portion of it's space is reserved for name and value. Although it's possible to change module size to square and move around text, the space reserved stays there for encoder and the control's proportions may become distorted in the process of resizing. It would make more sense if the size of the control would be decided upon selecting the type of control when it's added to the patch, and horizontal fader in initial choice should be added for that reason to save time setting it up.
]]>2018-02-19T00:02:07+01:002018-02-19T00:02:07+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39426#p39426Statistics: Posted by 23fx23 — 19 Feb 2018, 00:02
]]>2018-02-18T22:36:35+01:002018-02-18T22:36:35+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39425#p39425Statistics: Posted by x.iso — 18 Feb 2018, 22:36
]]>2017-11-17T01:28:22+01:002017-11-17T01:28:22+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=38553#p38553 Getting some time and use...found a bug. ListBox, if you put a text fader on the comma input with nothing it seems to complain Error: in paint.
Does the listbox have any way, or do you have a trick to treat it like a combo?
-s
Statistics: Posted by sephult — 17 Nov 2017, 01:28
]]>2017-09-15T18:23:39+01:002017-09-15T18:23:39+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37761#p37761Statistics: Posted by 23fx23 — 15 Sep 2017, 19:23
]]>2017-09-15T17:39:28+01:002017-09-15T17:39:28+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37759#p37759Statistics: Posted by x.iso — 15 Sep 2017, 18:39
]]>2017-08-27T12:31:24+01:002017-08-27T12:31:24+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37657#p37657couldn't reproduce the eye bug here, but worked on several things.
If wanna try this early version, i will try to check it all this week before posting new addon. v1.3
_New Vertical Caption Option _New Vertical Value Option
_New Mouse Wheel Interactions: On fader and Encoder will inc/decr value like usine defaults. ( pressing shift use 10x finer step). _On LisBox will control scrolling.
_ Value 'format' renamed to 'precision' (integer, .x, .xx, .xxx ect)
_ Relative Speed is now global, and available as input pin for more modularity. affects all items working in relative modes:ie fader,encoder,XY.
_ New Coarse-Fine switch input. if enabled, the relative speed is divided by 10. Alternatively, pressing CTRL on keyboard enable the fine mode. Or if enabled in global options, the item switch can control the fine mode as well.
_ Independant X,Y,Z min-max ranges instead of previously single global range.
_ To simplify a bit things W was removed, and Z contains swich ranged value.
_ better listbox input, previously was y and had to set range now explicitly called listbox input and auto adapts to list size.
_added Randomize and reset commands.
_ Global different Method, reducing Load. Previously all possible Items were created and existing per module. While this allowed to swich mode dynamically, this was meaning loads of tabs and settings, more ram used, more data to be saved in the wksp ect wich imo is bad if using lots of instances. Now user is requested to choose item type at creation, and it will then only create chosen item object, tab, and make adapted input-output pins and delete or hide irrelevant stuff. (for ex commatext and listbox pins will be there only if chosing listbox).
bad news, is , as many things changed internally and pins (like W removed) probably breaks compatibility in wks and presets
]]>2017-08-24T16:48:05+01:002017-08-24T16:48:05+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37638#p37638 We all know the busy
-s
Statistics: Posted by sephult — 24 Aug 2017, 17:48
]]>2017-08-22T17:31:23+01:002017-08-22T17:31:23+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37624#p37624Statistics: Posted by 23fx23 — 22 Aug 2017, 18:31
]]>2017-08-17T12:11:20+01:002017-08-17T12:11:20+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37570#p37570Settings/display not correct on reload
Found that my encoders are not saving design display properly. Top is how should be, below after reload. Just touching the resize will cause to correct.
-s
Statistics: Posted by sephult — 17 Aug 2017, 13:11
]]>2017-08-16T15:30:34+01:002017-08-16T15:30:34+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37563#p37563 I think I can reproduce that bug, and it might be in your module. If I select the main patch, and then the EYE visual settings tab....
Your modules are stuck in that tab and no longer display the other tabs. Once you switch to a different tab on the patch itself then go back to your module...the tabs come back.
-s
Statistics: Posted by sephult — 16 Aug 2017, 16:30
]]>2017-08-15T17:33:01+01:002017-08-15T17:33:01+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37559#p37559Statistics: Posted by gurulogic — 15 Aug 2017, 18:33
]]>2017-08-15T17:24:32+01:002017-08-15T17:24:32+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37558#p37558the tabs would contain far less options, like a basic quick overall color instead of individual ones stuff, reduced options to minimum, more using templates, stuff like that. the problem i faced when trying tho is that tabs aren't redrawn-populated 'dynamically' when we clic on them as i first thought, they are setuped once at the creation of the module, mean this 'toggle of mode' wouldn't be possible afterwards during operation. but what i can :feel ill do is request user at the creation of module, i suppose users wanting advanced mode won't need to revert back to a simple mode.
]]>2017-08-15T15:05:35+01:002017-08-15T15:05:35+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37557#p37557 I do agree with Senso on simplifying. You have a great module. I'll try to take a look here and maybe give you some ergonomic suggestions for simplification.
However, I actually like having options...this is totally the type of module I want....be very cool to have an advanced version and basic one.
-s
Statistics: Posted by sephult — 15 Aug 2017, 16:05
]]>2017-08-15T12:17:42+01:002017-08-15T12:17:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37556#p37556precision rather than format and tab make sense, mouse wheel should not be a problem to behave like usine modules. Ive seen there is an sdk function to rename the module that is new in HH3, maybe that broke the manual rename, or is in the way to be implemented, dk.. vertical caption should also be easy if it had been implemented in HH3 sdk, last time i tried on HH2 sadly it wasn't working tho the function was existing, i ll check. coarse/fine is indeed interesting what i curently use in another module i use is pressing ctrl divide delta change by 10 or i could add pin for more modularity yes, ill think about the swich idea option. but yeah i have to be carefull not bloating too much new pins like 8 minmax, 1 coarse fine ect that as senso asked me the other way around, to simplify the module, wich is alreay quite bloated with loads of options^^ but ill try to figure best compromises or mabe 2 version of the module. im thinking of mabe a request on creating the module if want it simple or advanced, or maybe two real different .usr..more maintenance tho. have to think about it, but let suggestions ill check possibilities
]]>2017-08-15T11:34:06+01:002017-08-15T11:34:06+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37555#p37555 Did we ever figure out a solution, or implement a way to replace all modules of one-type (usr included) with an updated version? God I hope we get this implemented...especially with as many of these TouchFaders I am using.
Regardless, I'd really like to see Senso have some sort of versioning of modules/scripts (obviously manual entry)/etc..... say in the settings. Could pull this from the module .plg files, possibly start creating a .plg file for usr modules too? This could just be a text entry that first reads from the .plg and if non-existent allows the user to input (for scripts, etc...).
Statistics: Posted by sephult — 15 Aug 2017, 12:34
]]>2017-08-15T11:20:54+01:002017-08-15T11:20:54+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=37554#p37554Damn good suggestion guru! My god I've been wanting to reduce my Coarse/Fine for synths like this for some time and had to come up with a bulky alternative (although it was cool because I had single-click increment/decrements acceleration)...still was bulky and close to defeating the reason anyway...haha.
again another +1
I would like to add another "relative" suggestion Have the ability, say on a fader or knob....when switching the cap, or switching the knob....to have the alternate precision increments/decrements be switched back and forth!!!! That would also allow native control without an inlet as well.....but you know...I was just being lazy and didn't want to feed it back in with a thru module...or forget and put in the non-deletable output-to-input wire...haha
I think between your craziness, guru's, and mine....here sometime 23fx23...you will have exhausted all the SDK options available on one module...which now is 128 modules and actually has a bigger footprint that Usine itself....is a standalone, and a VST....haha
-s
Statistics: Posted by sephult — 15 Aug 2017, 12:20
Statistics: Posted by gurulogic — 15 Aug 2017, 06:41
]]>BrainModularBrainModular Users Forum2018-02-21T11:21:42+01:00https://brainmodular.org/forums/app.php/feed/topic/55212018-02-21T11:21:42+01:002018-02-21T11:21:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39449#p39449Statistics: Posted by 23fx23 — 21 Feb 2018, 11:21
]]>2018-02-20T22:40:48+01:002018-02-20T22:40:48+01:00https://brainmodular.org/forums/viewtopic.php?t=5521&p=39445#p39445 another suggestion I forgot to share: is it possible to make TF-specific controls of visual elements accessible from inlets? for example I'd like to change size of XYpad dot dynamically depending on other parameters of what I'm controlling.
Thanks, Simon.
-s
-s
-s
-s
-s
again another +1
-s
