ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-09-14T08:01:42+01:00 https://brainmodular.org/forums/app.php/feed/topic/5509 2016-09-14T08:01:42+01:00 2016-09-14T08:01:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=5509&p=35871#p35871 <![CDATA[Error : GetEvtArrayData]]>
thank you.
have a nice in countryside.
Statistics: Posted by cmodica — 14 Sep 2016, 09:01
2016-09-13T22:23:32+01:00 2016-09-13T22:23:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=5509&p=35866#p35866 <![CDATA[Error : GetEvtArrayData]]>
thanx for your input.
that means I didn't solve the problem but there is a workaround.
for the quality I know where it comes from : it is a read only issue.
that will be fixed in V4, but as I mooving in the countryside, it will not be before few months...
glad you managed to play with this module.
I'll put some exemples sometimes when HH3 is released...
enjoy !
Statistics: Posted by oli_lab — 13 Sep 2016, 23:23
2016-09-13T09:54:35+01:00 2016-09-13T09:54:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5509&p=35861#p35861 <![CDATA[Error : GetEvtArrayData]]>
The V3 didn't solve the problem.
But the Error desapear by connecting an array to the array input at the bottom of the module and seting its size to the number of heads i choose when creating the module.
An other little bug is that it is impossible to chose the quality in quality menu of the module. I had the connect a ''list btn'' module to chose between LoFi, Interpolate or Filtered quality.
Thank you, i like a lot this Hydrogen module.
Great Job.
Statistics: Posted by cmodica — 13 Sep 2016, 10:54
2016-09-12T20:14:14+01:00 2016-09-12T20:14:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=5509&p=35855#p35855 <![CDATA[Error : GetEvtArrayData]]> I remember having done some quick fix between 2 and 3, but not sure what it was. this GetEvtArrayData is usually occuring when the module is waiting for data or audio and nothing is connected. I did some fixes about this issue but not sure...
anyway try to connect an array to the array input at the bottom of the module and set its size to the number of heads you choose when creating the module.
and please keep me informed of bugs if any.
Statistics: Posted by oli_lab — 12 Sep 2016, 21:14
2016-09-12T11:49:39+01:00 2016-09-12T11:49:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=5509&p=35849#p35849 <![CDATA[Error : GetEvtArrayData]]> i suppose he can help on this
[10:56:57] Load User Module : oli_lab_HydroGenV2.usr-osx32
[10:56:57] Error : GetEvtArrayData
Statistics: Posted by nay-seven — 12 Sep 2016, 12:49
2016-09-12T10:06:44+01:00 2016-09-12T10:06:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=5509&p=35847#p35847 <![CDATA[Error : GetEvtArrayData]]>
But everything seems ok when i play with it ...
did some could help me to understand and resolve it ?
The LogUsine file is here
thank you.
Statistics: Posted by cmodica — 12 Sep 2016, 11:06
thank you.
enjoy !
Great Job.
thank you.
