ArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-09-10T13:58:36+01:00 https://brainmodular.org/forums/app.php/feed/topic/5498 2016-09-10T13:58:36+01:00 2016-09-10T13:58:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=5498&p=35825#p35825 <![CDATA[Scripting: Clearing a Record or Custom Type]]>
Yes Creating your own types/records does work i will try to take some time in near future to update scripting wiki. So when you create a record you have to then create a variable attached to that record name. Like below the record name is (state) so you have to do something like (var loop:state;) then when you access the sub-records you say (loop.start:=45);
type state = record
start:single;
pos:integer;
last:integer;
max:integer;
end;
var loop:state;
loop.start:=45;
Statistics: Posted by sephult — 10 Sep 2016, 14:58
2016-09-07T22:48:57+01:00 2016-09-07T22:48:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=5498&p=35787#p35787 <![CDATA[Scripting: Clearing a Record or Custom Type]]> Statistics: Posted by ahonoe — 07 Sep 2016, 23:48
2016-09-02T01:52:00+01:00 2016-09-02T01:52:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=5498&p=35741#p35741 <![CDATA[Scripting: Clearing a Record or Custom Type]]>
midi_temp := Default(TMidi);
anyone have any better solutions, or know of any deficiencies with using this Default?
-s
Statistics: Posted by sephult — 02 Sep 2016, 02:52
2016-09-02T01:37:55+01:00 2016-09-02T01:37:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5498&p=35740#p35740 <![CDATA[Scripting: Clearing a Record or Custom Type]]>
I was curious and trying to find a solution.
I was wondering how you know the default values of a Record or Custom Type such as TMidi?
Also is there a way to clear a Record. I know you could probably create a function to do this, however I am not sure if there is a way to read how many parameters, nor access the parameters generically to do this in a custom function.
-s
Statistics: Posted by sephult — 02 Sep 2016, 02:37
type state = record
start:single;
pos:integer;
last:integer;
max:integer;
end;
var loop:state;
loop.start:=45;
-s
-s
