ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2017-05-03T08:37:00+01:00 https://brainmodular.org/forums/app.php/feed/topic/5423 2017-05-03T08:37:00+01:00 2017-05-03T08:37:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=36997#p36997 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]>
Sorry for bumping an old thread, but I have a similar issue, after a crash I lost my activation (along with the config, indeed), and my problem is that this computer can't go online (no wifi and faaaaar from my "internet box"). So I guess my solution would be the "activation key" ? I look for the way to get it, and I did not found how to do that.
Thank you in advance for any kind of help!
Have a good day.
Statistics: Posted by tanabarbier — 03 May 2017, 09:37
2016-05-24T14:28:20+01:00 2016-05-24T14:28:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35317#p35317 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> yes the first time you run a new version, it's normal Usine ask you to register
and best way is to import old setup .
Statistics: Posted by nay-seven — 24 May 2016, 15:28
2016-05-24T13:41:40+01:00 2016-05-24T13:41:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35316#p35316 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> - check activate then re-enter my login/password
- or now as you advise : by importing configuration of a copy of the app (MacOsX). Handy when I won't have any internet.
Statistics: Posted by Guybrush — 24 May 2016, 14:41
2016-05-24T12:10:36+01:00 2016-05-24T12:10:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35314#p35314 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> after importing your setup or register by entering your logins?
Statistics: Posted by nay-seven — 24 May 2016, 13:10
2016-05-24T10:52:31+01:00 2016-05-24T10:52:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35313#p35313 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> I've done my copie of a good version, by importing the setup, everything went fine.
So, everything should be ok for my gig... Still this behaviour isn't reassuring...
Statistics: Posted by Guybrush — 24 May 2016, 11:52
2016-05-23T12:51:28+01:00 2016-05-23T12:51:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35303#p35303 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> And I'm not using the last version (actually 82a). I'm gonna upgrade and the app copy as you advise.
I've also paid now for the lifetime licence so I won't have any issue in the future ;).
Thanks!
Statistics: Posted by Guybrush — 23 May 2016, 13:51
2016-05-19T17:41:05+01:00 2016-05-19T17:41:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35289#p35289 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> Sometimes C:// partition..
Statistics: Posted by nay-seven — 19 May 2016, 18:41
2016-05-19T11:55:14+01:00 2016-05-19T11:55:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35287#p35287 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]> When it's happen, you see the pop pup " usine is not free" and so ? you use the last 084a version ?
have you some crash of the program and lose your config ?
I will investigate
It's true that your license will expire at the end of May, but this not prevent you to use this version, only to upgrade for a new one.
What you can test is to
1 Enter your logins, once you see the "you are correctly registered" pop up, save your work and close Usine.
2 Copy the app ( if you're a Mac user) or the complete Usine dir (Win) and save it with a new name. Don't open or use it .
3 Next time Usine will ask you to register, use the import setup feature and give the path of this saved version.
must work
Statistics: Posted by nay-seven — 19 May 2016, 12:55
2016-05-19T10:44:21+01:00 2016-05-19T10:44:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=5423&p=35286#p35286 <![CDATA[Usine Hollyhock 2 asking me to activate it from time to time]]>
I've brought my Usine Hollyhock licence (June 2015 I think), entered my password on Usine : everything works fine.
But since a month or so, Usine "forget" from time to time my password and asks me to activate it. So I have to put back the password and it's ok.
Is that normal?
It will be a real issue as I'm gonna play on a stage without Internet in 2 weeks... and I fear that Usine blocks me...
What can I do?
Am I missing something?
Thanks for the help!
Statistics: Posted by Guybrush — 19 May 2016, 11:44
Have a good day.
Thanks!
I will investigate
must work
Is that normal?
What can I do?
