ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-06-03T04:42:14+01:00 https://brainmodular.org/forums/app.php/feed/topic/5422 2016-06-03T04:42:14+01:00 2016-06-03T04:42:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35362#p35362 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]>
Highly programmable, extremely sturdy/durable. You could beat a Transformer to death with it & use it at a gig that night.
No pressure sensitivity.
Statistics: Posted by shawnb — 03 Jun 2016, 05:42
2016-06-02T17:56:47+01:00 2016-06-02T17:56:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35361#p35361 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]> Statistics: Posted by grego mondo — 02 Jun 2016, 18:56
2016-05-22T10:14:18+01:00 2016-05-22T10:14:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35296#p35296 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]>
I use a roland FC300, nice unit but expensive. I also have a softstep I bought 1 year ago, but haven't used it yet :|
Statistics: Posted by La Tenaille — 22 May 2016, 11:14
2016-05-21T08:13:31+01:00 2016-05-21T08:13:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35292#p35292 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]> Statistics: Posted by Pianoscope — 21 May 2016, 09:13
2016-05-20T16:21:06+01:00 2016-05-20T16:21:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35290#p35290 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]>
The volume pedals don't have a lot of throw, but it's a lot of control for the $$.
Statistics: Posted by woodslanding — 20 May 2016, 17:21
2016-05-19T10:37:59+01:00 2016-05-19T10:37:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35285#p35285 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]>
There are nice things that you can do (long click, double click), and you're able to control the lights from Usine. I've done a looper sending back its state to the softstep : green light : playing, red lighting : recording, and one pad to control everything as each pad is able to send up to 6 messages!
Statistics: Posted by Guybrush — 19 May 2016, 11:37
2016-05-19T06:00:24+01:00 2016-05-19T06:00:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35284#p35284 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]> Statistics: Posted by Clearscreen — 19 May 2016, 07:00
2016-05-18T15:35:33+01:00 2016-05-18T15:35:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=5422&p=35283#p35283 <![CDATA[Which MIDI foot controller do you use and do you recommend ?]]> We have more and more new instrumentalist using Usine for their performance
and sometimes looking for a good advice about hardware, so i start this post series with Midi Foot controllers
Of course i know there are many different uses, but maybe some of experienced users here have some good foot controller to recommend to others ?
we can precise some criteria like weight, usb or external power, stability on the floor, easy to configure, switches noise and so
Statistics: Posted by nay-seven — 18 May 2016, 16:35
